subframe https://ausmini.com/forums/viewtopic.php?f=23&t=43203 |
Author: | the bean [ Sat Jun 21, 2008 9:47 pm ] |
Post subject: | subframe |
hi all i am going to do a engine conversion i was told $6000 will do it. but all i need to do is to get someone to cut the subframe and the rest i can do my self how much would it cost to get the subframe cut by a pro? thanks |
Author: | doogie [ Sat Jun 21, 2008 11:21 pm ] |
$6000 seems way to cheap, Brad 13secmini did his conversion & it cost him over 10K and he did all the work himself pretty much, Talk to Mr Enforcer in regards to the subframe PM minimad he'll happily tell you all about a starlet conversion (i assume thats what your doing) he's just gone through it all. Good luck, i can't WAIT to see how it goes. The Tool |
Author: | slinkey inc [ Sun Jun 22, 2008 4:52 pm ] |
Find someone who's done one (legally), and be very nice them, and get a frame built at mates rates to the same spec as theres, that way you know it'll pass engineering with the same engineer. |
Author: | Gordo [ Sun Jun 22, 2008 5:30 pm ] |
6k will be like being up a S%#@ creek without the paddle, i dont think 6k will quite do it... Cutting the subframe has got to be the easier part of the subframe process?? |
Author: | Archangel007 [ Sun Jun 22, 2008 6:10 pm ] |
Why dont you just buy one for sale? I know where there is a Morris with a 4EFTE conversion already done, all paint and bodywork done with wheels etc for about the same price ($6,000) This would be an easier route as most of the work has already been done. |
Author: | miniswift [ Mon Jun 23, 2008 5:54 pm ] |
Hi, If you are thinking that you can do it yourself once it has been cut. You must have welder and so on? I think you can save cost more buy doing cutting yourself as well as making it. All you nee to do is make a subframe jig as long as it keeps mounting to body fix, you can use anything....well, wood might not be good! This was one I made with scrap tubes I found at my work. Good luck Atchi |
