https://ausmini.com/forums/
Clubman & Toyota 20V Engine ??
https://ausmini.com/forums/viewtopic.php?f=23&t=40868
Page 1 of 3
Author:  Konzo [ Tue Apr 08, 2008 10:01 am ]
Post subject:  Clubman & Toyota 20V Engine ??
Would it work (size etc)?
Author:  Archangel007 [ Tue Apr 08, 2008 10:50 am ]
If you are talking about the 4AGE then - too wide!
Although, there is one going around in WA I believe (personal import from UK?) that has a 20V in it, enormous front track! No engineer in his right mind would approve it, especially in NSW.
There are better alternatives. :wink:
Author:  Konzo [ Tue Apr 08, 2008 10:52 am ]
I am looking at doing starlet conversion, just wondered if 20 valve would work.
Author:  Archangel007 [ Tue Apr 08, 2008 10:56 am ]
Nah, wont fit.
Author:  '77 clubby van [ Tue Apr 08, 2008 11:03 am ]
My Engineer told me that you can do pretty much anything, and as long as it is done well and safely you can get it rego'd. :shock: (At least in WA)
Obviously you need the skills and wallet to match this.
However you maybe pushing the boundaries of an ICV (Individually Constructed vehicle) which is required to meet most of the 2008 ADRs. - Think kit cars. 8)
Author:  spraycanmansam [ Tue Apr 08, 2008 4:07 pm ]
The 4AGE motor is my favourite motor.. EVER! If I could have done one sensibly I would have done that over the 4G92, but if you look at the pics of the mini that's done it, the guards are huge and the wheels stick right out! The track's enormous!! :cry:
So I guess it's possible, but like Trickory said -- there's better alternatives :wink:
Author:  4agecooper [ Tue Apr 08, 2008 4:23 pm ]
After doing my conversion, I reckon that it might be just possible to get it in a clubman with standard track, but it would be tight and very tricky indeed, therefore probably not worth the effort.
Mine is in a standard length roundnose front and because I needed the engine real close to the bulkhead there was not enough room for the suspension ,hence the extended track! Lucky for me I was in the UK at the time!!! :D
The 4efte certainly looks like a more straigh forward option - like any option is straight forward! :lol:
Rich
Author:  4agecooper [ Tue Apr 08, 2008 4:24 pm ]
p.s. It was approved by an engineer :!:
Author:  '77 clubby van [ Tue Apr 08, 2008 4:50 pm ]
You could always put it in the boot!!
mmmm......4AGTE mid engine.... or maybe sr20det.... :shock: 8)
Author:  Archangel007 [ Tue Apr 08, 2008 6:26 pm ]
There's a thought - mid-mount RWD would definately fit!!
And the precedent has been passed in QLD where Main Roads accepted it!
Author:  spraycanmansam [ Tue Apr 08, 2008 6:27 pm ]
Not hard either, use the gearbox out of the MR2 :wink: 8)
Author:  '77 clubby van [ Tue Apr 08, 2008 6:42 pm ]
:shock: Any info would be greatly appreciated. :D
Author:  Archangel007 [ Wed Apr 09, 2008 7:01 am ]
Hi James,
Just seeking permission from the person who sent it to me, to pass it on to you.
Must do the right thing! :D
Tricky
Author:  92 [ Wed Apr 09, 2008 8:38 am ]
I was going to fit a 4age before I looked at the 4efte and it is slightly wider but it still would fit just ment I would have had to cut the inner gaurds which the engineer was not keen on in SA but I really wanted to turbo it which Transport SA would not allow me to do, so 4efte it was.
Author:  minidrifter [ Wed Apr 09, 2008 6:30 pm ]
huh?? :?
i got flamed for even thinking about it, and by you aswell tricky :?
Page 1 of 3 All times are UTC + 10 hours
