Rover injected 1.3 https://ausmini.com/forums/viewtopic.php?f=23&t=38550 |
Author: | Treble [ Sat Dec 08, 2007 3:35 pm ] |
Post subject: | Rover injected 1.3 |
Hey Guys, I have a Mini Clubman (78') I have been offered a 1.3L Rover Injected motor, not sure if its spi or mpi. I'm just wondering if it is a worth-wile conversion over a carby 1275cc. because its looking like one or the other. I doubt i can afford a starlet conversion or the like at this stage. i figured that the rover motor may be a better option as i believe they are a later build (am i correct?) and therefore more likely to be in good condition. would this sort of conversion be "bolt in" or would i still need a different subframe ect..? Any advice would be appreciated. Cheers, Matt |
Author: | Kennomini [ Sat Dec 08, 2007 4:36 pm ] |
If it's fuel injected you'll need an efi fuel tank. Yes it should bolt straight in. Have you got disc breaks, you'll need them for a legeal roadworthy ![]() |
Author: | Treble [ Sat Dec 08, 2007 6:38 pm ] |
yeah, fuel tank included |
Author: | Archangel007 [ Sat Dec 08, 2007 7:36 pm ] |
Bolt in one would think! |
Author: | gafmo [ Sat Dec 08, 2007 7:41 pm ] |
MPI SPI get ride of it and go Carb..Same otherwise its the same..yepo make sure you have a disc set up thou |
Author: | Treble [ Sun Dec 09, 2007 5:11 pm ] |
what sort of power do these engines produce? |
Author: | drmini in aust [ Sun Dec 09, 2007 5:54 pm ] |
Treble wrote: what sort of power do these engines produce?
SPI was poor, MPI not much better.... ![]() around 61-63HP from memory. |
Author: | KLAS [ Sun Dec 09, 2007 6:26 pm ] |
SPi: 53 (3.1:1 FD) and 63HP (3.2:1 FD) MPi: 63HP only (2.76:1 FD) sadly not all engines are in good condition, just opened a 53 SPi engine and gearbox and its not realy worth to rebuild it |
