Starlet GT information https://ausmini.com/forums/viewtopic.php?f=23&t=38189 |
Author: | 1018cc [ Mon Nov 26, 2007 9:20 am ] |
Post subject: | Starlet GT information |
With thanks to "clubman77" clubman77 wrote: Hey Guys,
Just wanted to share a link to some Starlet GT information I found it looks pretty good. It appears to be a correlation of a lot or information that can be found on the net. So here is it: http://el31.com/starletgt.pdf Hope this helps some people out. Also it 1.5MB for anyone with a slow ISP. Cheers, Isaac |
Author: | '77 clubby van [ Fri May 22, 2009 3:19 pm ] |
Starlet GT workshop manual: http://www.jpnz.co.nz/afawcs0131170/CATID=26/SUBID=358/page=1/products.html |
Author: | amos [ Sun Aug 23, 2009 2:29 pm ] |
Should've put this here to begin with - instead of starting a new post: After some reading on the austarlet forum, i've come accross this link. It's bloody awesome for part number references. http://www.toyodiy.com |
Author: | amos [ Wed Sep 16, 2009 4:58 pm ] |
Post subject: | Kaaz Diff Part Number |
Here is a list of Kaaz diff part numbers http://www.swmotorsport.com.au/contents/en-us/toyota.htm |
Author: | Mearcat [ Tue Jan 24, 2012 9:11 pm ] |
EP82 Wiring details created by me ![]() Contains : -The wiring loom layout -A photo, ID of every connector -Quick reference table for Connector IDs -Conduction tables for the combination switches (lighting, indicators, wipers) -Fuse & relay ID's and pinouts -Wiring diagram of the instrument cluster (for my Gen 1 EP82) -The configuration of A/C Condenser and radiator fan relays and how they work in conjunction with the coolant temperature sensor and A/C refrigerant pressure switches. http://www.toyotagtturbo.com/forums/sho ... -available Direct Link tp PDF : http://www.toyotagtturbo.com/wiki/EP82w ... ectors.pdf |
