https://ausmini.com/forums/
4EFTE conversions - Air Conditioning..
https://ausmini.com/forums/viewtopic.php?f=23&t=37230
Page 1 of 2
Author:  _666_ [ Tue Oct 30, 2007 8:53 am ]
Post subject:  4EFTE conversions - Air Conditioning..
iknow its possible to fit a 4EFTE in a roundnose without lengthening.. but can you do it and still have airconditioning ?
Author:  cush [ Tue Oct 30, 2007 9:21 am ]
just wind the window down....
or wear more white..
Author:  slinkey inc [ Tue Oct 30, 2007 3:59 pm ]
According to Ben Afford, finding room for air con in a Leyland/Clubman is very hard.
It's on the list of things to do, but I'm a fair way off getting the 4EFTE into a Mini yet to even have a look. (Need a subframe first.)
Author:  minimetoy [ Tue Oct 30, 2007 7:01 pm ]
Short answer is NO :P
Author:  JC [ Tue Oct 30, 2007 7:24 pm ]
And the long answer would be WITH GREAT F...... DIFFICULTY!
Author:  sports850 [ Tue Oct 30, 2007 7:28 pm ]
Just as a random offshoot to this , with the way technology is improving would it be possible yet to have a small electrically powered air conditionerwounted somewhere (in place of a right hand tank perhaps?) , I know it'd draw a lot from the alternator but surely they are getting good enough now you could have a big enough alternator to run it ?
Oh yeah , I do realise this question will cause the photo of the Yank car with the house air con unit on the side window to be shown again .....
Author:  JC [ Tue Oct 30, 2007 7:58 pm ]
I think if you were going to do a conversion you would take a very holistic approach very early on. You would take the opportunity to change the subframe mounts to the front of the car and change the castor arm mount.
Author:  >Rude< [ Tue Oct 30, 2007 9:14 pm ]
havent seen it before but curiosity got to me n google is your friend lol, is it something along the lines of this??
Author:  sports850 [ Tue Oct 30, 2007 9:17 pm ]
Think more redneck , it was held to the side window with duct tape and had a honda generator bolted to the boot to run it ....
Author:  >Rude< [ Tue Oct 30, 2007 9:23 pm ]
lmao typed in "redneck aircon" in google
Author:  sgc [ Tue Oct 30, 2007 9:24 pm ]
Yep, that's the one :lol:
Author:  sports850 [ Tue Oct 30, 2007 9:25 pm ]
BINGO , though I also found this one .....
Author:  Mearcat [ Wed Aug 27, 2008 6:03 pm ]
I just had a thought about this... You can get self contained air con units for boats. I know a company called MarineAir make some (actually make combined heater/aircon units) but maybe too big for a small car.
Alternatively some trucks have 12V self contained systems for the sleeper cabs that can run while the truck engine is not running
-Alan
Author:  Archangel007 [ Wed Aug 27, 2008 6:13 pm ]
I am not buying into this.......... :shock:
Author:  Gordo [ Wed Aug 27, 2008 6:56 pm ]
I dont think an electric type of a/c will work. too much power drain with not enough results. If you want to use the 4efte air con you will obviously need to mount the a/c compressor to run off the belt. And then mount the condensor somewhere... You should be able to use a later model mini evap unit inside the car? Ohh and the alternator mountings are causing a hell of a problem in a few conversions, so i mounting the compressor will cause only more headaches.
But with ALOT of dedication it should work
