It is currently Thu Jun 26, 2025 6:29 am
 Post subject: K&N air filters????
PostPosted: Mon Oct 15, 2007 5:29 pm
Hey everyone,
Im looking at getting a K&N pod filter for my honda conversion, and was wondering what people would recommend?. Been looking at these two,
any other brands i should look at??
Thanks steve :wink:
Vtec Mini clubman. Commenced Jan 06.
Still Going June 07
http://s25.photobucket.com/albums/c71/sunburstvl/
PostPosted: Mon Oct 15, 2007 7:07 pm
both will work fine, just make sure you oil it once a year. They will be illegal to use without an air box, but i didnt have a problem in 3 years with mine, and was pulled over a few times for a look under the bonnet by the boys in blue.
Im pretty sure for best results a longer intake pipe is better then having it straight of the throttle body.
1974 Moke - 998cc
PostPosted: Mon Oct 15, 2007 7:39 pm
K & N dont filter as well as paper filters but they take less horses. So its power vs longevity
You drivein dusty aras get a denser filter so your engine doesnt suffer
PostPosted: Wed Oct 17, 2007 8:47 pm
Fram air hog filters are as good as k&n and are a little cheaper too.
PostPosted: Thu Oct 18, 2007 7:18 pm
Just picked up the K&N pod filter (top pic) on sale for $50 from AutoBahn so hopefully it will do the job
Thanks for replys
Steve :wink: :wink:
Still Going June 07
 Post subject: hi
PostPosted: Mon Nov 05, 2007 3:05 pm
also if your driving in dusty areas i think your not supposed to oil them as heavily
....or is it heaviererly??? :lol:
PostPosted: Tue Nov 06, 2007 11:05 pm
i would have thought the opposite as it's the oil that forms part of the filtration system
PostPosted: Wed Nov 07, 2007 9:17 am
Yes, true - traps all the larger particles and holds them in suspension!
PostPosted: Wed Nov 07, 2007 11:11 pm
lol yeh and it makes that nice film of ..... crud... always fun to clean :D
PostPosted: Thu Nov 08, 2007 2:03 am
yes, but using more oil doesn't help, it just drops out, gets sucked into the engine and reduces the flow.
for very dusty areas there are some foam filters to put over the cotton filters
Rover 214 atm ....
PostPosted: Thu Nov 08, 2007 6:43 am
KLAS wrote:
yes, but using more oil doesn't help, it just drops out, gets sucked into the engine and reduces the flow. for very dusty areas there are some foam filters to put over the cotton filters
Didnt say to use more oil, just remarked that the oil was a necessary part of the filtration process. :D
PostPosted: Thu Nov 08, 2007 7:00 am
yes, you did. and you are absolutly right.
but i thought it would be of any help to say that more oil doesn't filter any better as most K&Ns become overoiled when recharged
Rover 214 atm ....
PostPosted: Thu Nov 08, 2007 11:40 pm
yes i was more thinking of the foam style filters any ways
Mearcat wrote:
PostPosted: Fri Nov 09, 2007 8:00 am
I think that Finer Filter makes a foam filter with an outside foam 'sock' that you oil, wash, reuse etc.
Once they become too degraded, you simply replace the outer sock with a new outer element.
KLAS - I would agree with your last post. I dont thinlk that more oil makes them any more efficient during the filtering process, but it could make them less 'breathable'.
Tricky
PostPosted: Fri Nov 09, 2007 6:44 pm
Finer Filter is no more it got bought out a few years ago by Unifilter.
Yes they do foam filters with 2 layers, mainly for rally work and offroad, bikes etc.
http://www.uniflow.com.au/
BTW Unifilters outflow K&N, I've seen the evidence. 8)
I'm running Unifilters in both our Minis (1293 and 1360).
