It is currently Fri Jun 27, 2025 7:14 pm
PostPosted: Mon Sep 03, 2007 7:18 pm
Hi All 4EFTE builders
Quick question, mainly to the already registered cars
Have you guys been able to have your driveshafts inline from your hubs to the inner CV's?
Was this an important criteria that the engineer wanted?
I am having a few dramas with my VTEC project! Mine at the moment are on too much of an angle, engine is not far enough back.
Any help appreciated
PostPosted: Mon Sep 03, 2007 8:06 pm
i think mine were on about a 5 degree angle.
1974 Moke - 998cc
PostPosted: Mon Sep 03, 2007 8:08 pm
Hi Monda,
Yes, most of us have ours pretty much straight through - maybe slight angle of 1-2 degrees but nothing more (in saying that, I think Dean's is on a slight angle like 3-4 degrees).
The straighter you have them the less issues you have like torque steer and premature CV wear.
Tricky
PostPosted: Tue Sep 04, 2007 8:37 am
Thanks Guys, looks like I will have to work onit!
PostPosted: Tue Sep 04, 2007 2:32 pm
question: the engine squats under acceleration (i think :P) so you couldnt have it exactly straight cause it would end up with negative angle? has anyone worked out the optimum angle so that when it accelerates it will all be level?
PostPosted: Tue Sep 04, 2007 6:08 pm
Not exactly.
The suspension squats under braking, and raises (unloads) under acceleration.
The motor rotates around the mounting axis - in reverse to the direction of wheel rotation.
Therefore, the best angle to have the driveshafts is neutral and not leaning more to one or the other, as both conditions will be realised during driving.
Tricky
