https://ausmini.com/forums/
noob question
https://ausmini.com/forums/viewtopic.php?f=23&t=34379
Author:  chinky [ Wed Aug 01, 2007 12:40 pm ]
Post subject:  noob question
i'm in victoria, anyone engineers mini vtec conversion?
i wanna do one and get it right the first time....
any suggestions? subframe? engineer?
Author:  slinkey inc [ Wed Aug 01, 2007 2:29 pm ]
http://www.superfastminis.com
The kit looks good and all, but I'd check with the local authorities before buying one (yes he will ship to Aus, at a cost) as it appears the front track is altered, which may be an issue??
Author:  chinky [ Wed Aug 01, 2007 4:47 pm ]
yer i've done some research of all the subframes. But I am unsure which is enginerable (if that is a word)....
Author:  JC [ Thu Aug 02, 2007 7:44 am ]
http://www.mendozamechanical.co.nz/index.asp?pgid=54
Show it to an engineer. See what they think.
Author:  simon k [ Thu Aug 02, 2007 11:55 am ]
I reckon any sensible engineer would look at that one and go "eeeeeeekkk, get that thing away from me!"
Chinky, call Enkelman on (03) 9580 3024, they are reputed to be the best, and certainly were helping me out and proving to be very flexible, until I made a dumb mistake and Mr Enkelman terminated our relationship (not on engineering grounds - I'm forbidden to discuss specifics), but otherwise I'd still be using them. If you check in the conversions register sticky at the top of this forum, you'll see a few victorians are using them.
otherwise, check this page from Vicroads:
http://www.vicroads.vic.gov.au/Home/RoadSafety/VehicleSafety/ApprovalCertificatesVASS.htm
and follow the link to the pdf which lists ALL of the VASS approval engineers
edit: not so long ago, a victorian put an imported subframe in the forsales, stating that it was not possible to be approved in victoria - most likely due to track changes that were outside the allowable limits
