Perhaps this guy should have have a read of ausmini first https://ausmini.com/forums/viewtopic.php?f=23&t=34269 |
Author: | mattywood [ Sat Jul 28, 2007 5:37 pm ] |
Post subject: | Perhaps this guy should have have a read of ausmini first |
See this mini for sale on ebay. Widened and lengthened. Why? Its not like a mini doesn't have the space. http://cgi.ebay.com.au/ws/eBayISAPI.dll ... otohosting |
Author: | Timbo [ Sat Jul 28, 2007 10:56 pm ] |
What a lot of work, I wonder what he was going to do for a windscreen? Tim |
Author: | mattywood [ Sun Jul 29, 2007 8:50 am ] |
a 6 inch central pillar. ![]() |
Author: | slinkey inc [ Sun Jul 29, 2007 10:45 am ] |
There are at least another 3 threads about this car, was on ebay a few weeks ago. If you buy it, you'd be buying it just for the GTi parts, the Mini is just scrap metal value. |
Author: | dove grey 64 [ Sun Jul 29, 2007 11:02 am ] |
you'd have to make a custom bootlid,grille,bonnet,headlining,carpet,seats,dash,windscreens......the list could go on |
Author: | 9YaTaH [ Sun Jul 29, 2007 11:55 am ] |
Post subject: | Ewwww |
mattywood wrote: a 6 inch central pillar.
![]() 3 inch blind spots either side might be better ![]() |
Author: | Morris 1100 [ Sun Jul 29, 2007 5:30 pm ] |
You could always cut two windscreens three inches off centre and just use the two wide bits with a join up the middle. ![]() |
Author: | 9YaTaH [ Sun Jul 29, 2007 5:38 pm ] |
Post subject: | Large Mini |
Morris 1100 wrote: You could always cut two windscreens three inches off centre and just use the two wide bits with a join up the middle.
![]() and call it a Morris Oxford ![]() ![]() ![]() |
Author: | Morris 1100 [ Sun Jul 29, 2007 6:14 pm ] |
Post subject: | Re: Large Mini |
9YaTaH wrote: Morris 1100 wrote: You could always cut two windscreens three inches off centre and just use the two wide bits with a join up the middle. ![]() and call it a Morris Oxford ![]() ![]() ![]() |
Author: | goffy [ Sun Jul 29, 2007 7:16 pm ] |
Morris 1100 wrote: 9YaTaH wrote: Morris 1100 wrote: You could always cut two windscreens three inches off centre and just use the two wide bits with a join up the middle. ![]() and call it a Morris Oxford ![]() ![]() ![]() sticky tape does wonders ![]() |
Author: | Besser [ Wed Aug 08, 2007 9:09 pm ] |
Post subject: | make a buck |
You'd have to make a ply buck then cover it with sheet metal, lay some flat glass on it and heat till the glass relaxes over the buck. I was told this by an ex ferarri coach builder, still cant figure how the rubber in the laminate holds up to the heat? |
