JC wrote:
http://www.mendozamechanical.co.nz/index.asp?pgid=54
Show it to an engineer. See what they think.
I reckon any sensible engineer would look at that one and go "eeeeeeekkk, get that thing away from me!"
Chinky, call Enkelman on (03) 9580 3024, they are reputed to be the best, and certainly were helping me out and proving to be very flexible, until I made a dumb mistake and Mr Enkelman terminated our relationship (not on engineering grounds - I'm forbidden to discuss specifics), but otherwise I'd still be using them. If you check in the conversions register sticky at the top of this forum, you'll see a few victorians are using them.
otherwise, check this page from Vicroads:
http://www.vicroads.vic.gov.au/Home/RoadSafety/VehicleSafety/ApprovalCertificatesVASS.htm
and follow the link to the pdf which lists ALL of the VASS approval engineers
edit: not so long ago, a victorian put an imported subframe in the forsales, stating that it was not possible to be approved in victoria - most likely due to track changes that were outside the allowable limits
did I tell you that I won a
trophy?
