It is currently Thu Jun 26, 2025 11:28 am
 Post subject: AWD mini idea
PostPosted: Fri May 11, 2007 12:54 am
Just looking at half cut prices for absolutely no reason and came accross a car called the Subaru Vivio that i never heard of before. the half cut is going for 1300 and was supercharged 3 cyl so i looked round and found this
http://www.conceptcarz.com/vehicle/z583 ... fault.aspx
http://www.asianautospares.com.au/index ... &PageID=11
pretty cool stats if someone wants a 52hp AWD car and im sure you could turbo it or tweak it more. looks the same size as the mini. anyone thought of somethign along these lines using this car?
cheers, goffy
PostPosted: Fri May 11, 2007 7:32 am
Plenty have thought about it.
AWDMoke is giving it a red hot go. SKSSGN along with Archangel007 are trying a Honda AWD
If you seriously want to give it a go I have a Mitsubishi AWD for sale that would transplant well into a mini.
PostPosted: Fri May 11, 2007 7:52 am
Go Vivio. 0-100 in 18 seconds. You could drag race 850s against that. :P
I like the idea though
67 Deluxe under going full resto
PostPosted: Fri May 11, 2007 9:05 am
Is the new cruze 4wd?
PostPosted: Fri May 11, 2007 9:10 am
i've always liked the idea of a AWD mini.
if i ever did another project it would have to be a awd mini. wouldnt the biggest issue be the rear subframe?
PostPosted: Fri May 11, 2007 10:42 am
Yep!!
Keeps Simon and I awake at night sometimes!!!
Thank God for SolidWorks!
Tricky
PostPosted: Fri May 11, 2007 1:37 pm
the Cruzes based on Suzuki Ignis' have a live axle rear end.... I remember seeing one from behind when they were new and thought.... cheapo!!
PostPosted: Fri May 11, 2007 3:30 pm
anybody seen the rear cradle in a smart car? pretty compact. they are rear engined rear wheel drive for those who dont know. could use the rear arms from one of those. maybe even the cradle
PostPosted: Mon May 14, 2007 1:16 am
it would be fun imo
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu May 17, 2007 10:28 pm
I've got another AWD Honda, and a 1600 DOHC front cut that'll match up with it... and I'm having rear arms fabricated that will suit a slightly modified mini rear subframe. Get Tricky to make you a front subframe, I'll make you a back one, and you can pay for our conversion costs ;)
PostPosted: Fri May 18, 2007 8:22 am
we all know the fun is in doing it yourself :)
PostPosted: Fri May 18, 2007 8:14 pm
a girl around the corner from me has one of these, i dont think its forced though, i was stuck behind her and couldn't wait to over take her on 2 lane road,
i have really started an interest with kei cars, and when (not if) i finish some sort of apprentiship or tafe course, this is or the mini the type of cars i want to be driving,
i rang an import company about a suzuki alto turbo that they had complianced in QLD,
what the company also told me was that the gearbox mounts onto the suzuki mighty boy engine, and some type of suzu twin cam head mounts ontop, = 880cc twin cam turbo 4WD mini,
