https://ausmini.com/forums/
G13B-T Moke conversion!
https://ausmini.com/forums/viewtopic.php?f=23&t=29739
Author:  DaMokeMan [ Tue Mar 27, 2007 5:49 pm ]
Post subject:  G13B-T Moke conversion!
hey everyone!
i am currently half way through my latest project car... this being a moke that some of you may remember from mini shows... its the blue one with the racing seats and lots of speakers!
i decided that i would like to do an engine conversion as the 998 engine was really struggling with all the extra weight... this was originally brought about because i had a melt down with my wiring... the wiper motor shorted out and melted the whole wiring harness into one big clump of copper wire and rubber! i decided that while the wiring was all out that id get the engine rebuilt and beefed up to give it a bit more go! i was originally going to put a MG Metro Turbo kit on and build the engine for around 20 psi and hopefuly get around the 100 to 120 whp mark! but started to question the reliablity of a 1 litre motor putting out power in excess of 120 hp!
i then decided that a more power full starndard engine would be more reliable and better in the long run!
i decided on a suzuki G13B engine! i chose this engine because they are awsome engines and dont need much done to them to make them put out some awesome power!
next was to find some one who would do the engine conversion which proved to be hard because alot of people just said strait out that it was impossible and that it physically wouldnt fit in the engine bay! well i proved them wrong because andrew/Archangel007 on the north side of brisbane said that he would have no troubles making it fit, and it is now in his work shop being done!
as of now the sub frame has been modified and custom built to fit the G13B engine, the engine at this point is in the car and supporting itself!
there are still a few things that need to be done before it will be driveable! these consist of: all fuel lines and tank have to be fitted, drive shafts made to suite the swift engine, all brakes and brake lines have to be fitted, the swift gti original dash and dials are going to be modified to fit into the moke, custom turbo manifold and exhaust have to be made up!
after all that is done there is alot of body work being done, there is so much that its nearly impossible to list it all! but it will look good when its finished! its getting sprayed a custom dark pearl purple after i am happy with how the body looks!
then the whole wiring harness from the swift is going into the moke, then engine will be tuned up, then hopefully it will be driveable!
the G13B engine will be turboed in its current state, running standard compression.
i have a t25 turbo with an A/R 48 compressor wheel... the same turbos found on the CA18DET engines!
i will be using it with the standard actuator which runs the turbo at around 7-8 pounds of boost.
i know that swift gti's running standard engines with a computer chip and running 8 psi put out around 150 hp atw and runn low to mid 14's down the 1/4 mile. the moke being nearly 400 kilos lighter than the swifts should perform outstandingly well! the only issue im worried about is traction! but its no worries... some big fat tyres should fix that!
im hopeing to have it up and running for the mini show in june... but we'll see!
here are some pics of the progress so far!
this is the moke before the engine conversion started!
[/img]
this is approx where the intercooler will be mounted
this is the donor swift gti
this is the G13B engine
this is the engine in the newly made custom subframe, its fully supported by the sumbframe at this point, there is slack in that chain!
this is the wiring harness that i pulled out of the donor swift, the majority of this will be going into the moke!
and this is the turbo that i will bu using!
Author:  dove grey 64 [ Tue Mar 27, 2007 5:59 pm ]
looks cool, i hope your build goes as you hope and doesnt cause many dramas. your going to catch many a bug with your cooler up front. if i had a moke i'd be going for a dihatsu diesel 4wd engine and spray the car olive drab with rattle cans :lol:
keep us updated with the build
Author:  awdmoke [ Tue Mar 27, 2007 6:22 pm ]
That was exactly my idea for my next project!
Looks like I will be beaten to it - by about 2 years :oops:
The Mk 1 Swift is the way to go for mini/moke conversions for light weight
& good power, though the Starlet motor would be the choice for outright top end HP.
Keep us posted on the progress.
Author:  Blokeinamoke [ Tue Mar 27, 2007 7:42 pm ]
Look another Moke that will be finished before mine.
Looks like an interesting project.
Author:  DaMokeMan [ Wed Mar 28, 2007 10:15 am ]
Thanks for your comments and i will definitely keep you updated with the build
thanks
Author:  Zizzle [ Wed Mar 28, 2007 10:54 am ]
Now leave Tricky alone so he can finish the Cat. :wink:
Nah, seriously, good luck.
Author:  GTi_Mini [ Thu Mar 29, 2007 7:41 pm ]
nice to see someone using a MK1 engine. lol.
good choice. looking like progress is moving along nicely. keep up the good work.
Author:  Archangel007 [ Thu Mar 29, 2007 9:21 pm ]
Thanks Zizzle, The Cat does need some attention thats for sure (goes into the panel shop straight after Easter)
Jamies Moke will be finished this weekend, so out the door before Easter too!
DaMokeMan (Jamie) has big plans for this Moke, so I would keep an eye on this build....
Good luck Jamie and look out all you ricers!!
Tricky
Author:  simon k [ Sat Mar 31, 2007 3:30 pm ]
I reckon you should leave the moke looking as it is.... just with sticky tyres - keep it stock, then blow their doors off!! a moke doing 14 second 1/4's would be soooo very scary - it'll lay your windscreen in your lap!
Author:  DaMokeMan [ Sat Mar 31, 2007 4:56 pm ]
yeah 14 sec moke will be scary!
i had thought about leaving it stock on the outside and blow all the unsuspecting ricers away!
but the big front mount is a must have (just a personal preffrence of mine! lol)
but other than the front mount everything is pretty much stock on the out side, other than the paint and the unusually wide tyres and guards! :D
jamie
