It is currently Fri Jun 27, 2025 8:01 am
PostPosted: Tue Mar 13, 2007 9:54 pm
ok, silly question, use a manual starlet one? cant find one down here.... anything else the same?
also, apart from flywheel + clutch + gear box etc what do u have to do to convert a auto to a manual, have done it on a old datsun but that wasnt efi....
Im having trouble selling a auto front cut, thats all!
so, if anyone has a gear box set up for sale cheep, let me know!
regards, josh
PostPosted: Tue Mar 13, 2007 11:42 pm
you still trying to sell that. I remember seeing that about a year ago still $1,000 posted? BARGAIN if it is
good news is apparently according to the starlet guys you can use any e-series gearbox (4agze etc) Aussie starlet and MR2 others good too. apparently all line up and pretty much bolt right on. The N/A boxes have a slightly closer and a fractionally lower 5th gear though.
I am only learning toyota motors so apparently their engine code as long as it's FWD and ends in 'e' should bolt on. But check on the aus starlet club website before you rush out on my word, and I don't know if the non starlet boxes will have clearance issues in a mini. I have heard on a 4agze box in a mini with a 4efte tho...hope this helps you
and a few conversions:
13B Extend in a 1600
PostPosted: Wed Mar 14, 2007 7:55 am
hey buddy
I know!!! it hasnt sold, maybe its a sign for me to stop driving nissan crap and put it in my deluxe........
i tryed signing up to toymods but it wont let me:( oh well, ill try another forum!
so all I need is the box yeah? no different ECU?
PostPosted: Wed Mar 14, 2007 7:58 am
www.austarletclub.com
All you'll need is there for sale. Don't be affraid to ask questions, they are a helpful bunch.
PostPosted: Wed Mar 14, 2007 9:54 am
thanks mate, I signed up to that, should have my answer by this arvo.
thanks everyone!
PostPosted: Wed Mar 14, 2007 10:22 am
I would say that other than a speedo and reverse pick-up I can't remember any other things connected. I would say as long as theirs nothing massivley electrical in the auto box you will be fine.
I know you are going to a lot of trouble. but you might want to remind any buyers that a auto has a much faster pick up off the lights and even down the 1/4 they will be quicker, as they load up quite hard while stationary with a few revs
PostPosted: Wed Mar 14, 2007 10:58 am
..... and unfortunately no way its going to fit in a mini. I would love to have a starlet powered, manualised auto mini but they just won't fit.
PostPosted: Wed Mar 14, 2007 12:06 pm
A 4AGE geabox is an A series box. It's the second letter that is important, not the last.
What you need is a box from an engine with an "E" as the second letter. The 4EFE box from an Aussie delivered Starlet should fit, although probably has different ratios and may not be as strong. :(
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Mar 14, 2007 12:33 pm
send mini_man a pm hes got a spare na manual box + flywheel
also the "E" at the end of an engine code normally means EFI you need something where the E is the second prefix EG: paseo 5Efe as the 4a is a complely different engine series
4E = engine series F = close angle cameshafts T = turbocharged E = electronic fuel injection
1G =engine series G = wide angle camshafts T= turbocharged E = efi
57 Morris minor
88 Rover Mini
PostPosted: Wed Mar 14, 2007 12:36 pm
sorry to repeat bnicho
Im just tooo slow at posting and working at the same time :oops: :oops: :oops:
57 Morris minor
88 Rover Mini
PostPosted: Wed Mar 14, 2007 12:49 pm
No matter, your explanation was better than mine anyway. :)
Yep, a Paseo may be a possible donor too. The imported Sera with gull-wing doors also used the 5EFE engine. But I've never seen a manual one yet.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Mar 14, 2007 2:23 pm
All you will ever need to know about Toyotas.
http://www.sssautomotive.com.au/Engines/toyota.htm
PostPosted: Wed Mar 14, 2007 4:29 pm
You can fit corolla (4A) gearboxes to 4E engines......but the bellhousings are different apparently, So that part would have to come from a starlet/paseo/sera engine......
You can also fit the 6speed box from the 20Valve blacktop 4AGE.....
But you're best off to source a box from a 4EFTE.....will be the strongest, and have the best suited ratios
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
