It is currently Thu Jul 03, 2025 6:16 am
 Post subject: R1 Throttle Bodies
PostPosted: Mon Feb 05, 2007 5:23 pm
Just wondering whether this is a good thing,
I'm doing a turbo G13B and i'm going to have to modify the inlet manifold anyway so i thought i might go the bike carb route. I've been told its a good performance upgrade. Does anyone have any pics or info on the manifold needed and the total setup. Do you have to make up a seperated manifold going into the carbs?
PostPosted: Mon Feb 05, 2007 5:28 pm
I dunno about turboing through bike carbies?? I reckon it's either turbo OR bike carbies.
M
PostPosted: Mon Feb 05, 2007 6:01 pm
If you doing a G13B its fuel injected already, why go back to the carb method. And surely you can use the carbs though with a turbo setup but they might need some modifications to suit it...
Life's a garden.... Dig It!
PostPosted: Mon Feb 05, 2007 7:17 pm
Minboy,
Are you talking about using the efi quad throttle bodies from a bike?
Check out Borgy's mini (tiger strip) he has done this and the setup looks great.
Dan
PostPosted: Mon Feb 05, 2007 7:51 pm
Yeah i saw borgy's tiger in Miniworld and it said that it was turbo and used the R1 throttle bodies (sorry about the confusion), i was hoping that someone might have some pics of what he has done or what the setup roughly looks like.
Is it basically going to be a log coming from the turbo into 4 throttle bodies and then each one going into the inlet port.
Will this increase performance at all? - i suppose it will as you are getting more air in as long as your inlet pipe from turbo is big???
Will i need to run an aftermarket computer? How do you go about tuning?
Can Bike throttle bodies be used and engineered/registered?
PostPosted: Mon Feb 05, 2007 8:48 pm
I think i have some but might take a day or two to dig out.
Correct.
Yes it should, the nissan SR20 quad throttle body motors have more power.
Yes, You will have to have it tuned on a dyno.
Good question, not sure? would like to know.
Dan
PostPosted: Tue Feb 06, 2007 8:41 am
www.redlinegti.com.au has all the answers you need.
I would be looking towards an existing turbo charged quad throttle body set that is factory fitted to a front wheel drive car. Granted your options are limited when narrowed down that far but as soon as you find a GTI-R throttle body and plenum you won't need to look any further...... DAMN site cheaper than the R1 set up you are looking into aswell.
PostPosted: Tue Feb 06, 2007 4:44 pm
in miniworld it says borgy is running hyabusa not r1 ? ?
PostPosted: Wed Feb 07, 2007 6:25 pm
yes they are from the busa...... yes they make more power..... yes you will need a aftermarket ECU i recommend Autronic............ no you do not need a engineeres report for aftermarket injection.......... :lol:
