Wet subframe issue - Need Help Please!!! https://ausmini.com/forums/viewtopic.php?f=23&t=27050 |
Author: | ojmini [ Mon Jan 22, 2007 5:14 pm ] |
Post subject: | Wet subframe issue - Need Help Please!!! |
Hi everyone, I got a Morris Deluxe and planning to get the 4efte conversion done by Mr Enforcer. This shell have the hydro beg on front and rear frame. I would like to have full set of springs and shockers but I don't want to buy a dry subframe because it's going to be alter anyway. So is there anyone know how to remove the front hydro beg? Thank you |
Author: | JC [ Mon Jan 22, 2007 6:34 pm ] |
Let the fluid out. Keep the Hydro frames. |
Author: | Mick [ Mon Jan 22, 2007 6:53 pm ] |
The bag can be removed from under the wheel arches once the fluid pressure has been removed. The back are easy to remove, the front may need the upper arm to be undone from the frame to provide enough room. Do you mean you are doing a coil over shock modification, or do you mean you want to buy the rubber spring replacements? |
Author: | MiniGT [ Mon Jan 22, 2007 11:44 pm ] |
if you are removing the subframe to get it modified anyways the bag will be really easy to remove, once its out. |
