It is currently Thu Jun 26, 2025 9:53 pm
 Post subject: Driveshafts
PostPosted: Mon May 15, 2006 12:36 pm
Hi All,
For those people who have done, or are contemplating on doing a 4EFTE conversion, where did you get your driveshafts machined and how much did they cost?
Up here in Brisbane, there is only 1 or 2 companies that do it, and they charge an arm and a leg (and your first born!!).
Please supply contact details for the Engineering shops if able. :wink:
Thanks,
Tricky
PostPosted: Mon May 15, 2006 2:22 pm
Sorry to hijack... But if anyone has a contact in the sydney area that do good work for reasonable price, please pass on the details.
Pierre
PostPosted: Mon May 15, 2006 3:24 pm
Andy, I gather you are talking about the Bris Metro area? As most want the car in rolling chassis with engine so that they can take precise measurements. There is a fair amount of experience and engineering in insuring you cut and spline to the correct length etc. I got M&A engineering down here in the ACT to do mine and they wanted the car etc as did every other mob I spoke to.
Matt
PostPosted: Mon May 15, 2006 3:38 pm
Well I got MR Enforcer to arrange me some Billet Steel Driveshafts for $800
They are quoted to 800hp
Baracade
PostPosted: Mon May 15, 2006 5:31 pm
Hey, just finished making my own
Took me 3 hours to turn on my lathe at home and about 5 hours to set up the mill at work with the dividing head and cut 2 Honda and 2 mini splines...had them cased up and have them back in my hot little hands.........
Material was EN39b...carburising tool steel cost at $8.50 per metre
Freight and heat treatment was about $50
My time...if I was charging this out.......$500 ish......
Damn its good being a Toolmaker........alot of times :wink:
errr....and no, I don't take orders....
Glenn
If you idiot proof the world, only idiots there shall be!!!!!
PostPosted: Mon May 15, 2006 6:25 pm
Glenno
Err, good on you Glenno.
It would be a bit expensive freighting them to New Zealand anyway.
Tricky
PostPosted: Mon May 15, 2006 7:46 pm
I think of ya when ya write that cheque....... :cry:
PostPosted: Wed May 17, 2006 5:46 pm
Just took my shafts in today , should get them back in 2-3 weeks costing $300+gst for the pair
PostPosted: Wed May 17, 2006 7:56 pm
That is a GOOD price......I looked around before i made mine, prices ranged from $1000 for the pair to $200..............and the $200 was with a crowd that was only gonna do the splines.......had to supply them turned and centred.
I think my time was on the long side for the splining, but I am abit fussy and when its for yaself, time is irrelevant..........
If they are a specialized drive shaft centre, they will know all the tricks, but if its a local machine shop, make sure they radius all changes in diametres, leaving no sharp corners-stress risers.........
PostPosted: Thu May 18, 2006 6:21 pm
try getting onto 998clubman.
he got his done for his GTI somewhere on the northside of Brisbane.
i'm not sure of any other details.
Cheers, Cazmo
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Fri Jan 19, 2007 10:42 am
did anyone end up finding a place in brisbane?
Now driving a V5 and 3/4's
PostPosted: Fri Jan 19, 2007 4:50 pm
try this place at Sumner Park
http://www.raceengineering.com.au/mods.htm
Shorten and respline $148.50
I haven't had anything done with them. I just stumbled across this website.
PostPosted: Fri Jan 19, 2007 6:46 pm
Good work Cazmo.....
I shall give them a ring.
Tricky
PostPosted: Fri Jan 19, 2007 8:12 pm
yeah, let me know how you go. i'll be needing some driveshafts soon too.
PostPosted: Sun Jan 21, 2007 2:04 pm
Yes Cameron, good show.
