It is currently Fri Jun 27, 2025 3:19 am
 Post subject: Clubman Frames
PostPosted: Mon Dec 25, 2006 1:25 am
Hi guys new to the forum
own a 77 clubman mini.
mine and pops project. was going to put a Vtec into it but now after looking at this site have reaslied most are going for the 4EFTE conversion.
so my question is who can make a frame for the starlet engine?
was going to get a minitec frame from usa for the vtec but bit pricey.
can anyone help me out?
PostPosted: Mon Dec 25, 2006 6:06 am
where are you located buddy??? Helps heaps...
Amyway Merry Xmas
Mike
If it cant be fixed with a hammer it cant be FIXED!!
PostPosted: Mon Dec 25, 2006 12:28 pm
ah sorry forgot to mention located in newcastle
PostPosted: Mon Dec 25, 2006 2:15 pm
Mr Enforcer is located in Sydney and can do as much of the conversion as you want.
PostPosted: Mon Dec 25, 2006 2:48 pm
might have to give him a call.
does he use part of the original frame or starts one from scratch.?
was hoping to get one that can be fitted at home.
guess if it comes down to t can ship the car down there and front cut but bit of a mission
PostPosted: Mon Dec 25, 2006 2:51 pm
He modifies the existing subframe, that is what most people do anyway as it is easier and easier to get engineered too.
He also requires the car as most mini's are slightly different and he makes the frame in car.
PostPosted: Mon Dec 25, 2006 2:57 pm
might have to look into it once it gets closer.
just stripped out the inside and taken out the front subframe.
gotta cut out both front floors and go from there.
is it easier to get the 4efte done rather the vtec?
PostPosted: Tue Dec 26, 2006 10:09 am
I think to do a VTEC from scratch yourself would be slightly more difficult than a 4EFTE but only slightly. I heard there are a few issues to overcome with the VTEC which makes it tricky like the steering rack. But no engine conversion is straight forward. That's why alot of people buy the UK pre fab subframes if they do a VTEC as it removes all the guesswork. Pretty much bolt together...
PostPosted: Tue Dec 26, 2006 12:44 pm
we have changed our minds and have decided to do the 4efte conversion and make our own frame.
seems to be cheaper to get a front cut also.
