https://ausmini.com/forums/
Hi/Lo boost button
https://ausmini.com/forums/viewtopic.php?f=23&t=24735
Author:  minimetoy [ Fri Nov 10, 2006 7:34 pm ]
Post subject:  Hi/Lo boost button
Guys,
Can someone tell me what colour wires go into the back of the dash mounted hi/lo boost switch on the ep82.
Does any one know if it is an open circuit or closed?
Need to figure out how to wir it up.
Thanks
Dan
Author:  madmorrie [ Sun Nov 12, 2006 10:10 pm ]
Hey Dan
Took some pics of my loom and played with a multimeter across the pins of the plug. Seems to close the circuit between the two outer pins when pressed. The centre pin did not connect to the other pins either up or down. Only two wires though so I say its a redundant pin.
Wires are a brown and a green with brown (or maybe red) trace.
Hope this helps
Madmorrie
Author:  minimetoy [ Mon Nov 13, 2006 7:33 am ]
Your a legend Madmorrie.
Thanks a lot.
I'll have a look tonight.
Dan
