It is currently Thu Jun 26, 2025 11:27 am
 Post subject: The Pits
PostPosted: Mon Aug 21, 2006 5:59 pm
Hello All
In NSW after engineering etc, do we still go over the pits or can a Blue Slip station handle a vehicle with mods for Rego.
Thanks
Steve
PostPosted: Mon Aug 21, 2006 6:12 pm
Location: ¿¿ The War Machine's Alive § 99 Luft Balloons ??
I think the blue slip station is all that is needed now..
From memory the RTA did away with the pits years ago...
http://sexyurl.no-ip.org/mod3l0
PostPosted: Mon Aug 21, 2006 8:58 pm
Ah to be in NSW. In the ACT we have to get engineered and go over the pits. In my case 3 times!!!
PostPosted: Tue Aug 22, 2006 9:36 am
I'll confirm...
Yeah all you need is the Engineering Certificate & then a blue slip guy to blue slip it & do a engine # change
Baracade
PostPosted: Tue Aug 22, 2006 10:20 am
hey baracade, do u guys have to do all the emission testing etc in nsw, or do u just need an engineer to sign off on the quality of how thee conversion was done ?
andrew
PostPosted: Tue Aug 22, 2006 11:42 am
We just need the engineer to sign off...
Then the Blue Slip guy signs off on the rest and you are done.
PostPosted: Tue Aug 22, 2006 12:18 pm
so u dont need to emision tests or anything ?
if so then thats bloody awesome !
PostPosted: Tue Aug 22, 2006 12:22 pm
Emission Tests are not done on a engine change... only conversions that fall into kit catergory.
Baracade
PostPosted: Tue Aug 22, 2006 5:06 pm
wow u guys have it easy up there ! in victoria, unless u can prove that the engine u have came from an australian delivered vehicle and can prove its still runs all pre polution gear as well as computer gearbox and anything else, u have to go get emissions tests done, and they can be up to $1500 each time, with no guarantee ull pass it !
do u mean kit category as in like an ac cobra or lotus 7 replica style kit car ?
andrew
