What do you think will it fit https://ausmini.com/forums/viewtopic.php?f=23&t=18787 |
Author: | marcsvenson [ Thu May 04, 2006 9:27 pm ] |
Post subject: | What do you think will it fit |
Well what do you think?? hope i dont have to cut the body ![]() [/img] |
Author: | Monster Mini [ Thu May 04, 2006 9:48 pm ] |
I reakon you could fit two without much Trouble???? ............................................................................... ![]() ![]() ![]() |
Author: | harvey69 [ Thu May 04, 2006 10:19 pm ] |
easy fit |
Author: | JC [ Thu May 04, 2006 10:25 pm ] |
"Weeel, lookee heya maaaa, ain't she perrrdie" |
Author: | Mini Mad [ Thu May 04, 2006 10:27 pm ] |
Mmm...spaghetti drag V8... You'd whack one of those beauties into the back of a ute! |
Author: | minimetoy [ Thu May 04, 2006 11:34 pm ] |
You'd probably fit it in a roundnose, just need a big shoe horn. DAN |
Author: | =twista= [ Fri May 05, 2006 12:54 am ] |
striped 63 wrote: "Weeel, lookee heya maaaa, ain't she perrrdie"
Bahahahahahahaha ![]() ![]() ![]() |
Author: | Fat Boy Dave [ Fri May 05, 2006 6:49 am ] |
Author: | Baracade [ Fri May 05, 2006 8:50 am ] |
I'll attempt it!!!! Give me the motor... I'll pay someone to fit it to a mini Van |
Author: | minstar [ Fri May 05, 2006 12:04 pm ] |
Man that is what you call an intercooler. Plus I assume the same number of turbos on the other side (4 in all). I remember out at the Summernats one year an Indy (or something similar) engine (2.5ltr all alloy) putting out 800bhp. this engine even with the spaghetti was tiny and would have probably fitted in a cluby with minor mods to the firewall. Cost was a bit of a problem... ![]() M |
Author: | clubmn [ Fri May 05, 2006 2:56 pm ] |
Post subject: | mini |
I think if it turned up in my shed, we could make it FIT. If there is a will there is a way!!! |
Author: | HPDesign [ Fri May 05, 2006 3:40 pm ] |
without a doubt. if you can buy the engine then fitting it would only come to like well pocket change from the engine.I'd like to see it as Front wheel drive. You'd have the worlds worst torque steer and then the turbo's would cut in and then you would surley be dead. I would like to see it done, who has the motor and the mini? I'll dring a spanner, I recon that's all it'll take to fit it. ![]() |
