https://ausmini.com/forums/
MAP Sensor on the fritz again - any solutions
https://ausmini.com/forums/viewtopic.php?f=23&t=18539
Page 1 of 2
Author:  minstar [ Wed Apr 26, 2006 1:16 pm ]
Post subject:  MAP Sensor on the fritz again - any solutions
Well sorted out the missing or my mechanic did. Ends up I didn't tighten the screw for the TPS so as I went around corners it was moving side to side causing the car to miss. But last night I took her for a spin and the MAP sensor went on the fritz (again) causing the check engine light to come on. Checked code (31) MAP sensor.
Does anyone have a spare (that works) or can someone give me advice on an aftermarket that is compatible with the Starlet system?
Matt
PS. Hugh sorry I didn't ring you on the long weekend I was a bit flat out... :)
Author:  HPDesign [ Wed Apr 26, 2006 5:35 pm ]
That's OK INLAWS in Town anyeway.... I had "A BALL"
You can "borrow" mine until you can find a replacment. I won't need it for a while yet. Another MAP Sensor? that's bad luck or a sign of something more? you only did the last one not long ago.
Author:  minstar [ Wed Apr 26, 2006 5:48 pm ]
Nah Hugh still the original sensor. Sent it (with check engine light on) to Toyota who said there was nothing wrong with the sensor but still couldn't solve the problem. Then started it up the next morning and it solved itself! Now it is on the blink again.
Yeah if I could borrow yours then I can install it and see if it runs properly which would confirm that I need a new MAP sensor once and for all.
Matt
PS. I will give you a ring this week as I am wanting to go on the club cruise this weekend.
Author:  simon k [ Wed Apr 26, 2006 5:52 pm ]
Matt
sounds like a crook earth - 99% of electrical problems on modern cars are due to the ECU or something else not earthing properly
Author:  minstar [ Wed Apr 26, 2006 7:17 pm ]
Ok SK I'll give it a go. I must admit it all happened after I closed up the dash so maybe that's it something moves or the ECU gets shoved or something...
Author:  HPDesign [ Wed Apr 26, 2006 7:54 pm ]
not looking forward to your newfound spagetti junction of wiring are you?
well if that's the only downside I can live with it even though I appear to be failling Electronic component of my degree currently.
it's probably the only downside youve run into other than rego
Author:  minstar [ Wed Apr 26, 2006 9:38 pm ]
Hugh, trust me mate I am more than impressed with the engine. Like I said connected everything up and it started first go. The halfcut had obviously sat in the rain for quite a while so I expected that eventually something would go on the fritz. Overall I think the engine is brilliant and this is a small issue in the big scheme of things...
Hopefully I can sort whatever it is out before the run on the 29th?
Matt
Author:  minstar [ Thu Apr 27, 2006 9:18 pm ]
Simon Kerr, you're a legend. I took the dash off again and wiggled the loom inside the dash and the ECU aswell and she ran like a dream. Engine check light went off and he thing now idles below a 1000 and smooth as. Cheers.
Author:  Anto [ Thu Apr 27, 2006 9:25 pm ]
Does this mean we'll see you for the run on Sunday?? My Mini won't be there, but I should be. Depending on the night before, obviously. :)
Author:  9YaTaH [ Thu Apr 27, 2006 9:35 pm ]
Post subject:  So???
Simon already knows he is a legend Matt...just ask him :P
So are you sure it was a bad earth :?: Did you actually find something loose or poorly connected behind the dash :?:
See ya Sunday...hope you got my email today :)
Author:  CPOCSM [ Thu Apr 27, 2006 9:48 pm ]
???? - whats on Sunday??
I probably wasnt listening at the meeting(again...lol)
EDIT>D'Oh - Cooma..Dickhead Skins...
Hooroo
Rob Forsyth
Miniot!!
Author:  Anto [ Thu Apr 27, 2006 9:53 pm ]
I thought it was Yass? But then I wasn't listening at the meeting either...
Author:  simon k [ Thu Apr 27, 2006 10:00 pm ]
Post subject:  Re: So???
of course he's sure it was a bad earth - jeepers Mick, I said it was a bad earth, he checked what I said and it started working properly... theres no question, until it happens again, in which case the bad earth is fixed but something else is wrong - sheesh.... :lol: :lol: :roll:
Author:  CPOCSM [ Thu Apr 27, 2006 10:15 pm ]
I think it is Yass Anto - really really wasnt listening...lolol
Hooroo
Rob Forsyth
Miniot!!
Author:  9YaTaH [ Thu Apr 27, 2006 10:19 pm ]
Jeepers??????? :P Haven't heard that since Dennis the Menace....a similar person to Simon :)
Not everyone is as swept up as you Simon....I just wanted make sure that Matt didn't just jiggle and replace :idea:
ACTMCC run on Sunday leaves Hall 1000 for Yass or thereabouts.
