exhaust manifold studs https://ausmini.com/forums/viewtopic.php?f=23&t=17695 |
Author: | manofaus [ Wed Mar 29, 2006 11:53 pm ] |
Post subject: | exhaust manifold studs |
on the gti manifold the studs at the bottom have broken off. I can replace them with some grade 8 studs. Should I use stainless studs? I was thinking of using just grade 8 studs and making up some brass hex nuts, but twice as long then usual nuts. Or should I just stick with the grade 8 studs and steel nuts.....? |
Author: | drmini in aust [ Thu Mar 30, 2006 5:55 am ] |
Stainless is weaker. Trust me I've seen enough busted ones fixing outboard motors... ![]() I'd stick with grade 8. ![]() |
Author: | awdmoke [ Thu Mar 30, 2006 10:40 am ] |
Stainless also expands more with heat - not a good result on exhaust manifolds Go the brass/high tensile option! |
