gti subframe https://ausmini.com/forums/viewtopic.php?f=23&t=16838 |
Page 1 of 3 |
Author: | manofaus [ Sat Mar 04, 2006 6:56 pm ] |
Post subject: | gti subframe |
well its basically the same as most of the others that you have seen, except the bar at the front. I chose to bend mine and use 8 c/sunk 12.9 M8 hex screws. Still need to make the mounts up. more clearance needed for the rear of the g/box too. but it is progress..... ![]() ![]() ![]() ![]() ![]() |
Author: | inazuma_x [ Sat Mar 04, 2006 8:52 pm ] |
oooOOO purdy...looks alot like JC's ![]() no offense or anything but...is it just me or does it look a wee bit on the flimsy side? the one i've got planned sure is ALOT beefier than that...perhaps unnecessarily so ![]() |
Author: | manofaus [ Sun Mar 05, 2006 1:06 pm ] |
just you I guess.... engineer thinks its ok.... |
Author: | awdmoke [ Sun Mar 05, 2006 1:50 pm ] |
Looks like a neat piece of work ![]() I agree that a lot of the others are WAY over engineered! (I include my own in that category) |
Author: | mymini [ Sun Mar 05, 2006 3:33 pm ] |
Looks great , tidy work ....well done. Is my subframe the only one with a removable centre crossmember? i notice the 4fte's dont use one either? |
Author: | minimetoy [ Sun Mar 05, 2006 6:47 pm ] |
Looks good, Inazuma be careful not to overdesign and end up having unnecessary weight. Dan |
Author: | manofaus [ Sun Mar 05, 2006 10:38 pm ] |
my front bar is removable, makes it easier to install im my case... (c/sunk screws) lucky that the oil filter is not that hard to remove either.... I don't need to remove the bar to remove the filter. |
Author: | inazuma_x [ Mon Mar 06, 2006 8:16 am ] |
minimetoy wrote: Looks good, Inazuma be careful not to overdesign and end up having unnecessary weight.
Dan what size members did you use dan? i am looking at 50mm x 50mm RHS with 5mm walls...spose i could ask the engineer... |
Author: | JC [ Mon Mar 06, 2006 8:21 am ] |
Ina, you;ve got to remember how cramped for room it is in there aswell. When I read you "50 * 50" comment i got my ruler out and said to myself ">>ck that's huge". Anyway, good work Mano, Ron will be pleased to see his brainchild populating allover the country. |
Author: | inazuma_x [ Mon Mar 06, 2006 8:25 am ] |
striped 63 wrote: Ina, you;ve got to remember how cramped for room it is in there aswell. When I read you "50 * 50" comment i got my ruler out and said to myself ">>ck that's huge".
Anyway, good work Mano, Ron will be pleased to see his brainchild populating allover the country. 40x40 was my other option ![]() spose 50x50 is a bit on the massive side... |
Author: | awdmoke [ Mon Mar 06, 2006 9:48 am ] |
Don't go over the top with 5.0mm Wall Thickness A little bit of gusseting in the corners would be a lot more effective ![]() |
Author: | inazuma_x [ Mon Mar 06, 2006 9:51 am ] |
awdmoke wrote: Don't go over the top with 5.0mm Wall Thickness
A little bit of gusseting in the corners would be a lot more effective ![]() well i was gonna gusset pretty much every corner that formed a 90 degree...which is a fair few...i havent discussed any of this with the engineer as yet...i wanna make the jig first...then i will have a better idea of what i am gonna be doing...all i have at this stage is a few rough sketches and a mental image of how i want the finished product to look... PS sorry for hijacking this thread ![]() |
Author: | _666_ [ Mon Mar 06, 2006 10:04 am ] |
heres something to compare to guys... http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=8039363145&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1 |
Author: | inazuma_x [ Mon Mar 06, 2006 10:13 am ] |
hot DAMN! that thing is sexy...not the kinda thing i have in mind...that thing's a bit TOO radical in terms of its deviation from stock...i am aiming for something more like this: ![]() |
Author: | _666_ [ Mon Mar 06, 2006 10:15 am ] |
ahh yeah nice, i guess the one i posted is fair overkilll.. would a motor like that be more fuel efficient ? |
Page 1 of 3 | All times are UTC + 10 hours |
