It is currently Sun Jun 22, 2025 6:03 am
PostPosted: Sat Mar 04, 2006 2:32 pm
Hey guys, decided to build own jig but foolishly have cut my subframe to pieces :oops: . I need to know the distance between the bolt holes at top of the towers and the very front mounting points.
ie if you have two parallel lines, one going from one strut hole on one side to the other on the other side and the second line along the front plate, what is that distance.
Also the distance from the centre of front mount holes to top of the tower.
Thanks.
Daniel
PostPosted: Sat Mar 04, 2006 11:22 pm
My advice would be to borrow a subframe, and hope to heck its the same as yours.
