https://ausmini.com/forums/
Engine Bay Finished
https://ausmini.com/forums/viewtopic.php?f=23&t=16505
Page 1 of 3
Author:  minstar [ Wed Feb 22, 2006 9:56 am ]
Post subject:  Engine Bay Finished
Well, I have finished all the bits and pieces in the engine bay, just got to hook up the washer bottle. The grill is on just need to screw her together. Anyway here's some pics. It is down with Toyota right now getting the MAP sensor looked at (fingers crossed).
Matt
Update: Did dash too fits reasonablywell.
Author:  Baracade [ Wed Feb 22, 2006 10:19 am ]
Looks like its ment to be in their! VERY NICE
Author:  minstar [ Wed Feb 22, 2006 10:31 am ]
Thanks Dean, mate any developments suppose its a bit early. Have you got the engine out? Yeah mate if they can solve the MAP sensor thing I am away. Engineering here I come.
Author:  inazuma_x [ Wed Feb 22, 2006 10:52 am ]
yeah that looks REAL nice...i like the grille too...looks different but not TOO different that it looks outta place :) nice work!
PS is it just me or is there like smoke coming out of the IC?
Author:  minstar [ Wed Feb 22, 2006 11:33 am ]
No Inazuma it is the spirit of the occupant when it crashed (Christine Style). The same spirit that is trying to prevent me getting it engineered but I will previal :lol:
Author:  inazuma_x [ Wed Feb 22, 2006 11:55 am ]
oh true...it is on the inside of the car too :P so either its a smudge on yer camera lense...or its THE GHOST OF MINSTAR! personally i am puttin my money on option number 2 ;)
ooooOOOOO red button of doom (tm) equipped i see...press that and missiles pop out of the front fenders and blast your enemies to pieces right? :) or is it an ejection seat controller?
Author:  minstar [ Wed Feb 22, 2006 12:50 pm ]
Yeah injector seat activator. Only trouble is I have attached it to the drivers seat! Yeah I quite happy with grille apart from the stain from the radiator fluid pissing out. But I will steam clean the engine bay this week.
Author:  JC [ Wed Feb 22, 2006 2:46 pm ]
Are you still picking races at the lights or did you sort your idle out?
Author:  gzeVan [ Wed Feb 22, 2006 2:54 pm ]
I like the ignition conversion is that the starlet one or another toyota\mitsubishi one if you still have holes for door locks you should fit matching ones
Author:  998_Clubman [ Wed Feb 22, 2006 6:21 pm ]
:lol: looking good mate!! sorta wishing i went the toyota route now but i spose the suzuki motor looks better :P can you take some pics of the whole car? i dont think ive seen the whole thing before, just engine bay pics..
sooo close 8)
Author:  Baracade [ Wed Feb 22, 2006 7:25 pm ]
Yeah I cant remember seeing the whole car either!
Author:  9YaTaH [ Wed Feb 22, 2006 7:44 pm ]
Post subject:  Whoa!!
Looking absolutely evil Matt....you must be happy :wink: 8)
Author:  minstar [ Wed Feb 22, 2006 7:48 pm ]
Alright guys give me a few secs I'll be back. But first a couple of things. The guys at Toyota couldn't fix the MAP sensor issue :cry: . And the car overheated again on the way home. So I did some radical surgery to the front of the car. But! I pulled the lead off because I was going to do a continuity test on each of the wires going to the ECU anyway decided to take her around the block to see if my work on the radiator had worked and guess what the check light was off and the things revs like a demon again. Just hope it stays that way!!! I also put the thermo back... :D
Stripey yeah sorted it. I now sits on 1000 it was a combo of the TPS (to far forward so not sensing butterfly fully closed) and the hose to the MAP sensor had come off. Solve both and instantly went into a nice idle.
Pics to come...
Matt
Here's one before the conversion...
And another
Author:  9YaTaH [ Wed Feb 22, 2006 8:43 pm ]
Post subject:  YBZ
WHY BEE ZEE :!:
Author:  minstar [ Wed Feb 22, 2006 9:56 pm ]
Why Bee Zee Indeed. Yeah glad you like the look Mick, also you should see the hole I cut in the front to allow more air to the radiator. Needs a tidy up but will hopefully keep the thing cool.
Page 1 of 3 All times are UTC + 10 hours
