Tacho for a 3 cyl motor ??? https://ausmini.com/forums/viewtopic.php?f=23&t=16291 |
Author: | gzeVan [ Fri Feb 17, 2006 7:58 am ] |
Post subject: | Tacho for a 3 cyl motor ??? |
Does anyone know of a brands who sells a three cyl tacho they all seem to have setting for 4 6 8 |
Author: | 13secmini [ Fri Feb 17, 2006 8:44 am ] |
found this looking in google: http://theneonedge.zoovy.com/product/GS-709 And this: http://www.sunpro.com/product_category.php?id=289 |
Author: | Harley [ Fri Feb 17, 2006 9:05 am ] |
Maybe you could get a motorbike one? Do bikes have tachos? |
Author: | TurboOrangie [ Fri Feb 17, 2006 12:29 pm ] |
There are a few tachs out there for 3cyl's. I also have a 3 cyl in my car. I'm using the inner workings of the tach that came in the car from which I got the engine and putting them inside a custom Lucas housing. This way I will have a matching guage that is also accurate. I'm doing the same thing with the speedo. It's a bit of work, but it will be cool when it's done. |
Author: | gzeVan [ Fri Feb 17, 2006 3:59 pm ] |
cheers guys one of the tachos on 13secmini's link will work on practically anythingm, the dash on the sirion doesnt have a tacho so im looking for a clamp on style |
Author: | ausminis4u [ Wed Feb 22, 2006 6:44 pm ] |
hey mate you can use any after market tacho on a 3 cyl car. you just have to hook a resistor in line between the coil sense wire and the tacho. then switch the tacho to 6 cyl setting. ![]() |
Author: | gzeVan [ Thu Feb 23, 2006 7:29 am ] |
does the resistor vary from car to car (ohms) ![]() ![]() ![]() thanks for the tip the tacho i had in the dash isnt that old (its one of those ones that changes colour) |
Author: | minstar [ Thu Feb 23, 2006 8:00 am ] |
Most (modern) motorcycles have tacho's. The one on the YZF 750 SP I had went to 13,000! |
