https://ausmini.com/forums/
More Sirion conversion pics
https://ausmini.com/forums/viewtopic.php?f=23&t=15773
Author:  gzeVan [ Thu Feb 02, 2006 8:20 am ]
Post subject:  More Sirion conversion pics
Rear mount came up very well and was much easier than whet i first thought
The alternator swapped from back to front , They must have used it this way on a different model because it lines up perfectly :) :) :)
Just have to sort out the clutch ,Im converting the cable to hydrolic and have an Exel pin on a hilux slave cyl get havent had time to make the bracket :(
Author:  minimetoy [ Thu Feb 02, 2006 8:29 am ]
Some good workmanship there. Don't you like it when it all just comes together without a drama.
Dan
Author:  gzeVan [ Thu Feb 02, 2006 8:33 am ]
yes Everything has gone smoothly so far (knock on wood) :wink:
Author:  CJ_DT [ Thu Feb 02, 2006 8:15 pm ]
Looking good, I dont suppose you could post a few pics of the whole subfame in its current state, ie all mounted could you. I am interested in this conversion for the Ute project :).
Chris
Author:  gzeVan [ Fri Feb 03, 2006 7:18 am ]
Yes, the motor should be comming back out this weekend so i will get some good pics of the subframe then, ive got plenty of photo's the way it is i will get them all together :)
