Electrics Done...Almost there... https://ausmini.com/forums/viewtopic.php?f=23&t=15769 |
Page 1 of 2 |
Author: | minstar [ Wed Feb 01, 2006 10:27 pm ] |
Post subject: | Electrics Done...Almost there... |
Well rang the leccy today all jobs are done. Lights, indicators, wipers (all of the starlet binnacle), fuel pump etc. Wheel aligner is four doors down, so I will drop it off first thing tomorrow. If I can squeeze it in, its off to the Dyno on Friday in which case I have all weekend to spruce her up ready for the engineering test and if that's OK its off to the pits (RTA). Where it could all come unstuck. Still so close I can taste it... Cheers Matt. PS. Had alot of time on my hands so I decided to remodelled the grille ![]() ![]() |
Author: | inazuma_x [ Wed Feb 01, 2006 10:43 pm ] |
nice man black grille should look cool ![]() |
Author: | 13secmini [ Thu Feb 02, 2006 6:20 am ] |
im guessing that it will make between 120-125hp@wheels on 12psi ![]() Who else wants to have a stab? |
Author: | JC [ Thu Feb 02, 2006 7:30 am ] |
If you haven't played with the boost I'll go with 100hp atw. |
Author: | minimetoy [ Thu Feb 02, 2006 7:50 am ] |
Top Stuff Matt, can't wait to see it running, I'll be in Canberra in a few weeks so you'll have to take me for a run. Dan |
Author: | gzeVan [ Thu Feb 02, 2006 7:52 am ] |
Nice grill, ![]() |
Author: | minstar [ Thu Feb 02, 2006 8:41 am ] |
Yeah I chuffed about how the grille came out. Basically as I was cutting the guts out I left bits of the grille poking out all teh way round and then made fine holes in the mesh matching the little lugs. Then got the lugs to poke through the mesh and then bent them back thus holding the mesh in place. I take a photo from the back to give you the idea. As for the power output. I think it is anybodies guess. I think I should achieve above 100bhp, I think 120. Still its anybody's guess as it hasn't been run for what looks a long time so who knows. Don't worry I'll let everyone know. Cheers Matt PS. Getting wheel alignment today. Dyno on Monday. |
Author: | gzeVan [ Thu Feb 02, 2006 9:58 am ] |
thanks for the tips' Im playing around with a grill at the moment Im looking at something simular in silver Good luck with the engineering ![]() |
Author: | Baracade [ Thu Feb 02, 2006 10:02 am ] |
Grill is intresting.. My guess is 110 at the wheels |
Author: | inazuma_x [ Thu Feb 02, 2006 10:23 am ] |
Baracade wrote: Grill is intresting..
My guess is 110 at the wheels we could start a book ![]() ![]() |
Author: | awdmoke [ Thu Feb 02, 2006 11:03 am ] |
Put my $1 on 114hp atw |
Author: | gzeVan [ Thu Feb 02, 2006 11:07 am ] |
I will go the wild card entry with 133hp with a large top end peek |
Author: | minstar [ Thu Feb 02, 2006 11:30 am ] |
Thanks for the optimistic estimate. I will say 119hp. Everyone has to give an exact estimate (oxymoron). I post up the dyno sheet so it all above board. |
Author: | 13secmini [ Thu Feb 02, 2006 11:39 am ] |
Matt are you going to be upping the boost at all? do you have a bleed valve or boost controller? If your leaving it stock 9.5psi then 100-110hp@wheels should be about right. I think you can goto about 12-13 psi before the boost cut comes in, but at around that boost the ct9 wastgate starts to leak anyway, and the turbo is at its best effenciency range. |
Author: | minstar [ Thu Feb 02, 2006 11:53 am ] |
Yeah thanks Brad I keep forgetting about the standard boost level. I really wasn't going to do much re boost controllers etc until I have the thing on the road. Then I was going to weld up a new manifold with the T2 flange as you recommended then go a t25. The other issue is that I have those two black boxes that I showed pics of a few months ago. No one could tell me what they are but they a joined into the loom as it enters the ECU so I can't help thinking they maybe FCD's? I might ask Jake when its at the Dyno... Also Dyno booked for Wednesday so watch this space. |
