10inch wheels 4 new engine https://ausmini.com/forums/viewtopic.php?f=23&t=15167 |
Page 1 of 2 |
Author: | gzeVan [ Wed Jan 18, 2006 9:07 am ] |
Post subject: | 10inch wheels 4 new engine |
Ive decided to run with my 10inch wheels for the engine conversion because im using cooper s discs that will still fit, just wondering if any one has done this with good results or has everyone gone for 13's due to brake upgrades im running dunlop 10 70 165 tyres at the moment and the rim is 6 inches wide with wide offset |
Author: | 13secmini [ Wed Jan 18, 2006 9:43 am ] |
I think it will be fine for engineers if your running a non turbo motor under 1300cc. All the suzuki g13b guys run cooper s brakes, but most will admit that there not really upto the task, and some have gone to camira, honda, metro brakes and bigger wheels. You can always go the KAD 4 piston calipers on the 7.5inch discs, but big $ there. |
Author: | inazuma_x [ Wed Jan 18, 2006 9:46 am ] |
$2500 for a set ![]() personally i am going 13's over civic brakes... |
Author: | gzeVan [ Wed Jan 18, 2006 9:58 am ] |
guess i wont know until i get i running ,the motor is 50kg less weight so that should help most race cars would use the KAD setup wouldnt they so the can keep the smaller wheels I love my speedy hotwires they give it a good retro look |
Author: | benjamin [ Wed Jan 18, 2006 10:58 am ] |
if you already have the s discs the kad calipers alone are $1200 |
Author: | gzeVan [ Wed Jan 18, 2006 12:02 pm ] |
thats a bit more resonable ive aready spent $$$ to rebuild my brakes but thats a good future option are the KAD calipers much better in the way of claping surface area |
Author: | inazuma_x [ Wed Jan 18, 2006 12:35 pm ] |
WHOA! didnt realize brembo actually make aftermarket brakes for the Rover Mini...OMFG! BREMBO BABY! thats some ricey crap! might have to look at getting a pair ![]() |
Author: | fuzzy-hair-man [ Wed Jan 18, 2006 12:54 pm ] |
I am guessing they use the S brake pads so the pad surface area won't be any more but I don't know anything about them ![]() EDIT: Sorry it says these are for 8.4" disks ![]() |
Author: | benjamin [ Wed Jan 18, 2006 1:10 pm ] |
most maybe all 4 pots use the metro turbo pads which are bigger than s calipers, another option is alloy 4 pots , $899 a pair from minisport sa just make sure you get the ones for 7.5 solid discs |
Author: | gzeVan [ Wed Jan 18, 2006 1:45 pm ] |
the price is getting better ![]() that would have to be the best bang for your buck brake upgrade for a mini no matter what size wheel you have |
Author: | awdmoke [ Wed Jan 18, 2006 2:08 pm ] |
inazuma_x wrote: WHOA! didnt realize brembo actually make aftermarket brakes for the Rover Mini...OMFG! BREMBO BABY! thats some ricey crap! might have to look at getting a pair
![]() ![]() That is the Brembo part # on the top RH corner Wonder how much they are? |
Author: | inazuma_x [ Wed Jan 18, 2006 2:16 pm ] |
i'd get a set of those in a second...like 1.0 seconds flat! if they were under $3000...for 2 front rotors and calipers... |
Author: | inazuma_x [ Wed Jan 18, 2006 2:29 pm ] |
Model: MINI Mini / Mini Cooper 1.3i Year: 97-01 Front: * Rear: Part number: 08.5464.10 ?: 213 TH: 9,5 Min TH: 8,6 This is from the brembo website (http://www.brembo.com) 213mm is 8.4" so they'd fit under 12's...very very VERY interesting...maybe i should start a new thread... |
Author: | willy [ Wed Jan 18, 2006 4:11 pm ] |
I don't think they make calipers for the mini... just rotors. And note; not everything Brembo is HIGH PERFORMANCE; they do make OEM stuff for factory replacement. |
Author: | inazuma_x [ Wed Jan 18, 2006 4:22 pm ] |
willy wrote: I don't think they make calipers for the mini... just rotors.
And note; not everything Brembo is HIGH PERFORMANCE; they do make OEM stuff for factory replacement. really? so they make rotors that they dont make calipers for? that seems a bit stupid...i wanted it more for bling-factor...so the brembo tagged calipers are actually MORE important than brembo rotors... ![]() what honda brakes to people usually put on their minis? civic? what generation? |
