https://ausmini.com/forums/
help with bloody annoying bolt on aircon unit...
https://ausmini.com/forums/viewtopic.php?f=23&t=15053
Page 1 of 2
Author:  inazuma_x [ Mon Jan 16, 2006 11:24 am ]
Post subject:  help with bloody annoying bolt on aircon unit...
i am considering just grinding the nutt off and then seeing if i can slide the aircon unit off over that...is this a bad thing to do? someone has rounded off the nut on it during a previous install...
its the one you can see below the red (momo corse) oil filter...
here's a closeup:
Author:  awdmoke [ Mon Jan 16, 2006 11:29 am ]
It's your call, but I would remove the oil filter & use a pair of Vise-Grips
Author:  inazuma_x [ Mon Jan 16, 2006 11:36 am ]
the position of the oil-filter isnt actually a problem...i can get spanners and stuff in there without any trouble...
hmmm...vise-grips...not a bad idea...the only prob is that there's almost no working room...i'll make a stop in at the local hardware store to see if i can get a pair this arvo...might do the trick...if not...its angle grinding time...
Author:  minimetoy [ Mon Jan 16, 2006 11:39 am ]
Or you could usse a Metrich spanner, will remove rounded nuts.
Or just grind through the nut untill you almost reach the thread and the you will find it will come of fairly easy after that.
Or just chop it off. You wont need it.
Dan
Author:  inazuma_x [ Mon Jan 16, 2006 11:49 am ]
cool thats good to know...i'll see if i can get a metrinch spanner from the hardware store near me...
Author:  Zizzle [ Mon Jan 16, 2006 1:30 pm ]
Can try giving it tap with a chisel too. See if you can get it to turn.
Author:  TurboOrangie [ Mon Jan 16, 2006 1:48 pm ]
Use a pipe wrench (I'm sure you guys have much better word for it and will make fun of me.) that will get it off way better than vise grips as long as there is room for one.
Author:  awdmoke [ Mon Jan 16, 2006 2:52 pm ]
Stillson
or monkey wrench to you Yanks :P
There, happy now? :lol:
Author:  inazuma_x [ Mon Jan 16, 2006 3:06 pm ]
managed to source a 12mm metrinch spanner that should be arriving tomorrow via post (total cost $20 inc. postage...ick)...if that doesnt work i am gonna take the grinder to it...too much time and money on 1 bolt that i dont even need...
Author:  fuzzy-hair-man [ Mon Jan 16, 2006 3:42 pm ]
If you take the grinder to it how about grinding some flat sides to the nut and then trying a spanner on it :wink:
Author:  inazuma_x [ Mon Jan 16, 2006 3:48 pm ]
coz that's too tricky...might as well just take the whole thing off...there's limited room and i cant be bothered frigging around with trying to grind tiny bits off it...would rather just nuke it...
Author:  drmini in aust [ Mon Jan 16, 2006 6:52 pm ]
can't you fit a DEEP 12mm single hex socket in there? 3/8 drive, of course.. :wink:
Author:  inazuma_x [ Mon Jan 16, 2006 8:19 pm ]
dont have one of those...just got a normal socket set...
Author:  TurboOrangie [ Tue Jan 17, 2006 10:53 am ]
I'm no Yank. I'm Canadian eh!
Author:  awdmoke [ Tue Jan 17, 2006 11:03 am ]
:lol:
I though you were going miss that one. :wink:
