Oil feed to turbo https://ausmini.com/forums/viewtopic.php?f=23&t=14862 |
Author: | minimetoy [ Wed Jan 11, 2006 8:18 pm ] |
Post subject: | Oil feed to turbo |
Now that i am making a log for the exhaust manifold i have thought about removing the factory oil relocator altogether and simply fitting the standard oil filter. I will pick up the oil feed for the turbo by installing a T-piece where the oil pressure switch is relocated. Any comments or issues that people can see with this? Dan |
Author: | JC [ Wed Jan 11, 2006 8:29 pm ] |
Post subject: | Re: Oil feed to turbo |
minimetoy wrote: Now that i am making a log for the exhaust manifold i have thought about removing the factory oil relocator altogether and simply fitting the standard oil filter.
I will pick up the oil feed for the turbo by installing a T-piece where the oil pressure switch is relocated. Any comments or issues that people can see with this? Dan We must have different models as mine doesn't have a factory oil relocator. Is there enough room in the round nose to fit the oil filter in the standard location? JC |
Author: | minimetoy [ Wed Jan 11, 2006 8:54 pm ] |
The factory relocator is really an offset piece fitted where the oil filter would go on an 4efe. All 4efte models have this due to the turbo position. I think the standard oil filter will fit with out a drama. Dan |
Author: | minstar [ Thu Jan 12, 2006 8:27 am ] |
Yeah doesn't it simply sit pretty much flat against the engine? |
Author: | NoMoreMinis [ Thu Jan 12, 2006 9:55 pm ] |
T-piece on the pressure switch is working fine on mine......that's how most people do it.... |
Author: | JC [ Thu Jan 12, 2006 10:19 pm ] |
minimetoy wrote: The factory relocator is really an offset piece fitted where the oil filter would go on an 4efe. All 4efte models have this due to the turbo position.
I think the standard oil filter will fit with out a drama. Dan I spied what you where talking about tonight. Looked at it and realised "oh, it's offset" must a been what the dude was on about", the "relocator". |
