What Type of BOV? https://ausmini.com/forums/viewtopic.php?f=23&t=14861 |
Author: | minimetoy [ Wed Jan 11, 2006 8:15 pm ] |
Post subject: | What Type of BOV? |
Guys, What sort of BOV should i use with my 4efte? I am running a T25g turbo. Dan |
Author: | JC [ Wed Jan 11, 2006 8:32 pm ] |
What level of boost are you going to run? |
Author: | minimetoy [ Wed Jan 11, 2006 8:55 pm ] |
Not sure yet? Dan |
Author: | JC [ Wed Jan 11, 2006 10:07 pm ] |
I'm going to recycle as many of the factory parts as possible, but it has been said that I am frugal. Bosch is good enough for Posche to use on their turbo cars, should be up to the task. Of course they didn't use that model but you get my drift. |
Author: | Baracade [ Thu Jan 12, 2006 8:41 am ] |
I like going for the best parts Ie:TIAL... But Turbosmart has a good enough rap too! |
Author: | inazuma_x [ Thu Jan 12, 2006 8:43 am ] |
i am planning on getting a TiAl BoV when it comes time for one...i am not quite as frugal as JC ![]() |
Author: | 13secmini [ Thu Jan 12, 2006 12:58 pm ] |
anything from hks, blitz, apexi, tial, turbosmart, trust, gfb will be fine, try to find a second hand one connected to a pipe already for an easy fit. I got my hks one for $70 with the pipe and just plumbed it in the standard location. ![]() |
Author: | kazjim [ Thu Jan 12, 2006 3:58 pm ] |
"Bosch is good enough for Posche to use on their turbo cars, should be up to the task. " Up to about 12PSI .... I've killed two Bosch Plastics so far .....The Diaphragm splits at about 12PSI Boost ..... I've got a Blitz on there at the moment, but its pretty worn out...leaks a little vacuum at idle now .... Off to get a Tial or HKS on the weekend .... J |
Author: | JC [ Thu Jan 12, 2006 5:34 pm ] |
Tis why I asked what boost level he was going to run..... |
Author: | benjamin [ Thu Jan 12, 2006 6:32 pm ] |
i like the turbosmart vee port type 2, real nice sound and is also adjustable, looks tops too ![]() |
Author: | NoMoreMinis [ Thu Jan 12, 2006 9:59 pm ] |
I've got a HKS SSQV......very distinctive sound....and loud as all hell using the standard toyota one will make it easier to get past the engineer though wont it? |
Author: | minstar [ Fri Jan 13, 2006 7:17 am ] |
Yeah I thought about recommending this route to Dan, but then remembered that going with a T25 and a log exhaust manifold means the standard piping probably goes out the window. I said to Dan that you have to match your BOV to the kind of boost your running as they are set to different levels is this correct (that's what I was told)???. |
