It is currently Mon Jun 23, 2025 4:55 pm
 Post subject: ep91 or ep82?
PostPosted: Wed Nov 23, 2005 11:49 am
ummm...found a wrecker with front-cuts of both of these...which one is better for a conversion? doesnt look as though it matters :S although the ep91 they have has waaaaaay less km on it and is only $300 more :P
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 12:03 pm
ep91 came out after 95?? i think. They had a slightly different turbo ct9a instead of the ct9 in the ep82, think they had 3-4 more hp..
What kms do they have on them?? mine had 88 000kms and was $2000 for 93 ep82.
Also dont always believe what kms are on them as most are wound back. Just by looking at the engine sometimes you can tell if the kms are close, or open up the cam cover and see how clean it is in there.
For $300 more i go the lower km one and you also get a better dash you can use or sell.
1974 Moke - 998cc
PostPosted: Wed Nov 23, 2005 12:39 pm
the ep91 (for $1800) is 70,000km and the ep82 (for $1500) is 145,000km...if its just a choice based on that i'd be stupid not to get the ep91...i would have thought...both are running and in good mechanical order (according to the wrecker)...he wants a $500 deposit with payment of the balance within 2 months...
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 1:37 pm
Where are they Drew? Place I was telling you about? If you can, go check them out. I believe some of the EP91's have a balancing shaft like the GTI's do. You might have gotten lucky and found one of those. Maybe the EP91's have ABS too. Could be a handy module to sell......
PostPosted: Wed Nov 23, 2005 1:46 pm
yeah the place you told me...dont think my scooter's good to get out there though...too far :( i am thinking of putting a deposit down on it coz apparently there's a bunch of people coming out tomorrow to look at it...
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 2:59 pm
hmmm...apparently the ep91 they have is basically just motor (no radiator) and gearbox...they said it looks like it was hit on the front-end...and most of the passenger side is missing :P no dash or anything...the ep82 is in MUCH better condition apparently...its more or less a complete front...wheels, shocks, dash...everything...its got 146,000km on the clock though...seems like quite alot to me...both motors run though...
i am leaning more toward the ep82 now...although the number of kms it has is a bit worrying...might try other wreckers to see if they have anything...
what do you guys think?
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 3:18 pm
Mine is an ep82 front cut and had 131k on it and cost me $1,650. Found the turbo was seized which did not bother me as at the same time I got a T25g. You will find that most Jap places do not give any warranty on the turbos themselves.
I sold the parts that i did not need at a discounted rate just to get rid of them and got $500 for them, if my panels had not been damaged i would have been able to pick up a bit more.
Funny, nobody was interested in the ABS, so it will go to the recyclers.
The EP91 has the coil inside the dizzy, otherwise externally they pretty much look the same.
Dan
PostPosted: Wed Nov 23, 2005 3:21 pm
would it be worth going the one with 147,000km on it for $1500? the ep91 sounds a bit...i dunno...you dont get much with it...which is annoying...you dont even get a radiator :P
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 3:32 pm
hmmmm...nothing...none of the other wreckers have anything better...most dont have anything at all...the best one looks like either the ep91 or the ep82 as mentioned before...but which one?
Bling me up Scotty!
PostPosted: Wed Nov 23, 2005 4:31 pm
It'd be a big bonus for you if either of them have a factory LSD.....
I'd be more worried about the damage to the wiring loom than the missing radiator, as there's no way you'd fit a starlet radiator in a mini anyway. If the EP91 cut has front damage, look for damage around the turbo/exhaust manifold.
it's a hard question without seeing them, but i wouldnt be too worried about the k's on the ep82 cut.....toyotas are very well built, and you shouldnt have any problems with it. I'd say that'd be about average k's for an EP82 cut.
Jeremy
1962 Morris 850.....with a 1310
1998 Toyota starlet.....161.1hp atw
PostPosted: Wed Nov 23, 2005 6:15 pm
spose i could just get it reco'd too...if i feel really crappy about the massive mileage...
Bling me up Scotty!
PostPosted: Thu Nov 24, 2005 3:33 pm
bought the ep91...its missing a few things...had a small prang on the passenger side...but runs awesomely...has factory LSD and ABS...missing passenger side shocker and hub/wheel assy...but everything looks good other than that...been canibalized for a few bits n pieces (radiator for 1) but looks like a good donk...
Bling me up Scotty!
PostPosted: Thu Nov 24, 2005 3:59 pm
aslong as the motor, box, all the ecu, wiring, driveshafts, gearshifter and cables, turbo and engine mounts thats all you really need. :D
1974 Moke - 998cc
PostPosted: Thu Nov 24, 2005 4:08 pm
LSD too - lucky sod!
Try & get the wrecker to throw in an electric fuel pump too - either the donor car one or anything from a 2L NA motor will do. Lots cheaper than buying a Bosch one later :wink:
PostPosted: Thu Nov 24, 2005 4:12 pm
yeah its got all that...
Bling me up Scotty!
