pump pressures https://ausmini.com/forums/viewtopic.php?f=23&t=12770 |
Author: | mini_matt [ Wed Nov 02, 2005 4:31 pm ] |
Post subject: | pump pressures |
does any one know the pump pressure is on a metro turbo equiped mini. i know carby around 3-5 psi but the malpassi reg wil keep it under control . but what pressure pump do i get. i think i have to keep it 4psi + what ever the turbo is pumping in. will efi pump be to much with the reg ![]() |
Author: | JC [ Wed Nov 02, 2005 6:11 pm ] |
Post subject: | Re: pump pressures |
mini_matt wrote: will efi pump be to much with the reg WAY too much. 30psi sound fimiliar.
Author: | Jules [ Thu Nov 03, 2005 12:16 am ] |
Yes, pressure at the carby must be 4psi more than the pressure in the plenum chamber so you will need a regulator to achieve that. Therefore the pump must supply at least 4psi more than your maximum boost pressure. EFI pump will do the job. |
Author: | mini_matt [ Thu Nov 03, 2005 4:46 pm ] |
Post subject: | fuel |
very good. another one i know efi engines run surge tanks to stop fuel surge. but carbys have float chamber to store fuel. now would i be wise in installing surge tank just to be sure ![]() |
Author: | Jules [ Mon Nov 07, 2005 10:13 pm ] |
Carby float chamber is indeed a surge tank, so no need to add another one. |
