It is currently Sun Jun 22, 2025 2:12 pm
 Post subject: After Market ECU
PostPosted: Sat Sep 03, 2005 3:05 pm
To avoid what all you are having trouble with is it possible to (if the budget allows) purchase a aftermarket engine management ?
TwinCam Mini has a aftermarket ECU, will the use of one of these not require me to pull the harness of the half cut and re install it. :D :D
 Post subject: Re: After Market ECU
PostPosted: Sat Sep 03, 2005 4:03 pm
Yes.
PostPosted: Sat Sep 03, 2005 8:20 pm
Depends on the road rules in your state
In SA I have to run the standard ECU to get past emission rules
4efte powered Clubman
supercharged 998 race car
PostPosted: Mon Sep 05, 2005 12:13 am
PM me I can get people a good deal on a New LOOM & Microtech ECU...
If you are in sydney can arrange a top bloke to install it at a good price toooo
Baracade
PostPosted: Tue Sep 06, 2005 8:58 am
Is there anything you can't do, Dean???
PostPosted: Tue Sep 06, 2005 9:43 am
Haha yeah I can't do it all...
I just have now met people who can... & seeing I am spending big money with them... they have come quite friendly with me...
Baracade
PostPosted: Thu Sep 08, 2005 2:38 pm
the problem is getting it past. but i think there is away around it. but its got to be pin locked by your mechanic or something stupid like that.
but its not that hard to put the std loom through, just have to sit down and work it out.
i don?t suggest you use aftermarket ecu until you put it all together stock and make sure its all working be for you take the next step.
Twincam GTi Powerd mini
