It is currently Sat Jun 21, 2025 9:19 am
PostPosted: Fri Aug 26, 2005 9:55 am
I am new to all of this and was just interested how much will it cost for me to get a subframe manufactured to fit a Gti engine in to a clubman. ( I haven't got any mechanical experience so I won't be doing any of the work)
Also does anyone know of any places in Melbourne where I can get a subframe made up.
PostPosted: Fri Aug 26, 2005 6:23 pm
you will be looking at anything from $1000-$3000 for one that would be able to get engineered.
1974 Moke - 998cc
PostPosted: Sat Aug 27, 2005 11:53 am
If you want someone in Melb to make the subframe, Link Automotive in Mitcham may be able to help.
However if you want someone who's made a few of the subframes and has refined the design try Dennis Turner (DTMINI on this forum) as by all acounts, he's the man!)
PostPosted: Sat Aug 27, 2005 12:52 pm
I reckon it would be hard for someone to justify $3,000 for a frame. It's more than likely that you would be givingthe builder just about everything they need to do it (in the way of research). They would just be bending up some tubing and welding it all together. Granted there is a lot of fiddly stuff but that's all fairly straight forward.
It should also be noted that this is not a job that you should take on if you aren't prepared to do heaps of little things yourself. If someone is going to do it for you they will be charging it at about $60/hour. You would need to have VERY deep pockets if they are to do everything for you.
PostPosted: Sat Aug 27, 2005 8:03 pm
Thanks for that I only need the engine conversion part done for me the body and iterior I can do myself. Do you know how much it will cost me for the installation of the engine itself. :D
PostPosted: Sun Aug 28, 2005 9:30 am
minigti, where to start mate, you should have a search through the forum first
how much to "put' the engine in, mayte common, suzi front cut $2k, frame $2-$3k, drive shafts, disc brakes, fuel pump, custom brake lines, dual circuit system, cooling, ALT setup argh!!!!
i can confidently say now you will need a lot more than 5k to start.. with your mech knowlege, id say you wouldnt have much, if any change from ten grand!
SCROLL down on this page a little, and have a read, this has come up to many times..
:) http://www.ausmini.com/forums/viewtopic ... hlight=gti :)
hmmm good luck.. 8)
GTi Turbo'd mini, abused daily
PostPosted: Sun Aug 28, 2005 7:06 pm
Thanks Mate, I might have a think about this for a while, and have a chat to a few mechanics. Dos anybody know of any good ones around the melb eastern suburbs
PostPosted: Mon Aug 29, 2005 9:23 am
998, I made the subframe myself, already had vented metros on the car etc etc and so far I have been through close to $7K. Where does the money go??? If you see a kidney for sale on Ebay... :wink:
PostPosted: Mon Aug 29, 2005 5:33 pm
yeah ministar it say he'd have no change from 10 grand, its just that mine cost me under 3 on the road 8)
actually, bout $3500 with rego and third party
PostPosted: Mon Aug 29, 2005 6:20 pm
hmmm i may need to sell two kidney's
Baracade
PostPosted: Mon Aug 29, 2005 6:47 pm
With what you've spent on your monster Dean,
it'd be 2 kidneys and the money you'd save on alcohol for the next 10 years :lol:
PostPosted: Tue Aug 30, 2005 10:39 am
Good effort 998. I did alot of things that probably aren't strictly necessary so I could have probably got it done for less. Things like 0BX Buckets, Koni Shocks, conversion to dry cone etc, push up the budget.
