It is currently Fri Jun 20, 2025 4:26 pm
Post new topic Reply to topic  [ 73 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: MINIWRX
PostPosted: Wed May 28, 2014 7:35 pm
Hi all
This is not really an engine conversion but a DNA infusion.
I am converting a 1964 Morris 850 to have the floor pan, fire wall, suspension and AWD running gear from a Subaru Liberty.
It currently still has the original 2.2 NA engine but this will eventually be replaced with a 2.5 STI engine.
Because of the "major structural modifications" the hybrid will be classed as an ICV (Independently Constructed Vehicle) by the NSW RTA. It will be road registered.
I will update this thread with pictures as I go.
Below is the shortened chassis !
The view most other road users will see !
Regards
Phil
 Post subject: Re: MINIWRX
Wow!!!
Dusk Blue
1964 850
PostPosted: Wed May 28, 2014 7:38 pm
Holy crap! :shock:
Looks quite fat on the wheels, and the work is for the most part done already!
I'm keen to see the rest. How did you go about building the chassis?
PostPosted: Wed May 28, 2014 7:43 pm
Yes please. Can you make 2?
PostPosted: Wed May 28, 2014 7:53 pm
So cool.
PostPosted: Wed May 28, 2014 8:29 pm
Mick wrote:
Holy crap! :shock:
I cut all of the excess bodywork off the Liberty and welded in some telescopic RHS with a 540mm gap which is the difference between the liberty and mini wheelbase.
Cut the bit out in the middle and winch the two halves together.
I designed the space frame to comply with CAMS roll cage regulations in case I want to race it.
PostPosted: Wed May 28, 2014 8:35 pm
Do you have to extend the front?
PostPosted: Wed May 28, 2014 8:57 pm
Yes, 150mm, it sounds a lot but it is largely camouflaged by the massive wheel arches so it is not that noticeable (unless you park it beside a standard mini).Image
The complete front flips forward for access.
Now that's access !
PostPosted: Wed May 28, 2014 9:00 pm
Impressive work. How long have you been working on it?
PostPosted: Wed May 28, 2014 9:16 pm
Impressive work I can't wait to see the progress and finished masterpiece
PostPosted: Wed May 28, 2014 9:21 pm
I have been building this for about 4 years in limited spare time.
Progress has slowed lately due to purchase of a 64 850 with a 1275 engine. Tidying that up to get registered and then back to the "real project".
I now need to rip out all the excess cabling from the liberty loom and install that. Currently there is way more loom than there is space for it.
PostPosted: Wed May 28, 2014 10:57 pm
fark! awesome :D
PostPosted: Thu May 29, 2014 1:44 am
Yeah wow! looks awesome. Look forward to seeing this finished. You said something about panning to put the engine from an impreza into it?
Why Drink And Drive When You Can Smoke Dope And Fly!?
PostPosted: Thu May 29, 2014 1:51 am
What did you do to shorten the driveshaft? is it actually the stock one shortened or have you replaced it with one already the correct length? Like these guys did with their corolla AWD mini: https://www.youtube.com/watch?v=NSbo6E5zycc
PostPosted: Thu May 29, 2014 6:27 am
Still looks amazing. Makes me think all sorts of dangerous creations. Great fab skills too.
