madmorrie wrote:
Nice work there Pub.
That sure is a mess of wiring. Is that the whole loom including the A/C and heater loom? I thought there would be less wires than that!
Must have another look at my loom, it's in a box outside somewhere...
Are you trying to interface the two looms, or just using the whole starlet loom as a replacement for the mini one?
Madmorrie
That is the wiring loom minus the A/C, door control and all that other stuff that is not needed!... the clutter is mainly due to the sheer length of the wires.. After I finished cutting them and shortening and lenghtening them as necessary, I was left with a full sized green shopping bag worth of wires + relays etc etc!
.... The car still started fine and everything worked so I haven't screwed up anywhere
92 wrote:
I only used 2" intercooler piping on mine yes it helps with lag and you see bigger engines making 200+kwatw with 2" pipes so I don't think they restrict it enough when we are only making 150
Thanks for that Ben.. you're right.. After reading numerous forums on the net about raging debates about this... seems like 2" is plenty for the power we are chasing.. so I have infact bought all the gear necessary for 2" system.
..I'm using 2.5" for exhaust.. trying to squeeze that sort of tube from the turbo etc
I dont think I have the patience to plan it properly.. 2" should be that much easier to route
92 wrote:
You can rotate the comp housing on a CT9 it just mucks up the actuator mounting so that has to be modded
yay!
This would make life a lot simpler.. good news to start the day
Thanks for all your help fellas!
cheers!
