It is currently Tue Jun 24, 2025 11:33 pm
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Sun Feb 22, 2009 3:14 pm
d1ck0 wrote:
Interesting way of mounting the Master Cyl and Booster.
If you are going to weld things you may as well start with the brakes. :lol:
PostPosted: Fri Mar 06, 2009 3:30 pm
Actually having another look at those mounts he has used - (like these - http://www.altraline.com/pics/jul_2005/481-8108_IMG.JPG), I thought they are only really good for compressive strength. Under heavy acceleration in a FWD car/ transverse engine - the mount as he has oriented them they will be under tension and could pull apart, but then in cornering loads, the force of the engine moving laterally from left to right will evetually sheer those mounts in half !!
Unless you over engineer it and use big mounts used for a V8 or something? Landrover ones are about 75mm diamater :? But I also recall you can get a collar that goes around these types of mounts.
-Alan
PostPosted: Thu Apr 09, 2009 6:23 pm
After a few weeks off the road, everything has been bolted back in and the mini is back terrorising the streets. The engine came out, bearings were checked (all good it seems) and the oil sump was resealed. The frame was re-welded with a new gusset where the crack was and a few welds were improved while access was available. Hopefully this should be sufficient to prevent any further breakages. The original plan was to make up a tensioner for the mechanical water pump but after the belt was minced on the first run with no obvious obstruction we ended up going for an electrical pump mounted near the boot. There were a few leaks that needed to be tracked down and fixed so that was also taken care of while it was up on the hoist. While everything was out all the shiny bits were treated to a quick buff. Also, once everything was back in, a wheel alignment was carried out (seems to drive a fair bit straighter now). Thanks to Scott and Nigel for carrying out most of the work for me and hopefully there wont be too many problems in the future.
PostPosted: Thu Apr 09, 2009 8:18 pm
I'ld be tempted to put some sort of box around that pump.
PostPosted: Fri Apr 10, 2009 9:24 am
Being plastic I would have to agree JC!
Good to see its back on the road though, well done champ!
PostPosted: Fri Apr 10, 2009 11:14 am
I've been looking at modifying the radiator scoop so that it picks up more air when on the highway and was planning on protecting the pump at the same time.
PostPosted: Fri Apr 10, 2009 11:38 am
Yep, good idea.
How hot does it run?
PostPosted: Fri Apr 10, 2009 10:01 pm
It used to reach 100 degrees as soon as you spent any period of time over 100km/hr with the mechanical pump. Although I took it for a run tonight to watch the test and tune at Willowbank and sitting on 110 it didn't get any hotter than 92 degrees. It could be a different story on a hot day but.
Users browsing this forum: No registered users and 21 guests
