No seriously solid mounting is just not really an option in my books,,, unless it`s in a motorbike where here is virtually no strain from excess weight/torque & smooth as a babys bottom with very few harsh harmonics
a car is a whole different kettle of fish & really should never be solid mounted,,, it may be a little obvious my bias tho
Soloid mounting just fatigues & rattles & shackes everything to death & the theory of "Go-Kart" flexable frame situation just should never enter the equation in a road or race car
as you`ve pointed out mini mad,,, even a small amount of insulation would suffice,,, just that it would need to be thought out & not just simply "Mounted" ,,, if you get my drift
There`s an old saying in the performance automotive fabrication industry & that is--->
"Strength by design & not by materials"
& that simply means that you really don`t need a piece of railway track or bridge girder to make something last,,, but in the same sense , a piece of cheap chinese string won`t fair well as an engine mount either .
& i`m not even going to start on the micro vibrations that not only cause you to go insane with the vibey noise (resonance) & constant fatiguing breakages,,, but also the amount of time needed for continual repairs & maintenance of said solid mounting product,,,
It`s absolutely nothing new,,, it`s all been done before,,, (As you all of you already know & i really shouldn`t bother typing all this, so more for the average punter or unitiated) tried & proven to the "Nth" degree & the results are that are an intellegently designed subframe & engine mountings assembly really shouldn`t need any continuing maintenance or (breakage repairs),,, unless of course you are going for the go-kart style, barest of essentials, minimalistic, lightweight , pure , out & out , race car situation.
Of which a road starlet powered mini is not.
There are plenty of mega horse power race & road cars with Nolathane (or similar product) type engine mountings which have been designed along the same lines as mini engine steady bar bushes (altho usually one piece & i`d ecpect to creat something a little larger in length/diam etc) & work quite fine over many many years of abuse,,, including nearly every single (decent) off road racing buggy or sand rail etc,,, a small amount of insulation & intellegent design goes a very very long way
ok,,, i`m done before i open another can of worms,.... oh ,,, too late
carry on,,, nothing to see here
