Bernard,,, i`m thinking about that,,, But i`m not sure what would be a fair price to charge if i did sell them,,, i know how much time i`ve spent but i certainly can`t charge that out at an hourly rate,,, no one could afford it
but at the same time i wouldn`t want to give them away either, effectively shooting myself in the foot (again)
However, i have had other people suggest that maybe the people who buy them could then get that price discounted off the price of the conversion kit if they did buy one & i think that`s quite a fair proposition,,, but it`s really back to how much should i charge???
& the unleaded question,,, well they (the 8v heads) actually became unleaded at around 1985 ,,, but there are many people who will suggest that they`re all unleaded (miniboo & many others,,, sorry miniboo
) but they All really were "Tough" valve seats & can run on unleaded anyway,,, just that they weren`t "Truely" unleaded until 1985.... You can check what head you have by popping out your exhaust valves & if you have a groove around the outside of the valve seat insert then you have an unleaded head,,, if they don`t have the groove then they`re pre-unleaded heads,,, Engine numbers & frame numbers can be checked to confirm,,, but if you only have the haed & no engine & no bike frame then the only way to tell is by the exhaust valve seat insert grooves ...But as i`ve said,,, either way they can run unleaded because they`re all "REALLY" Ph`kn tough valve seats anyway
However i`m pretty sure that "all" the 16v heads were unleaded.
But,,,,, Hhhhmmmmm,,,, how much to charge for the build guide on it`s own????
