It is currently Sun Jun 22, 2025 10:08 am
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Aug 17, 2005 12:58 pm
Brilliant M and I noticed you have even cut the front off the frame, so you've made a start. I gather you will be locating the turbo over the gearbox rather than extend the front? Very nice Mini by the way, very neat.
Thanks,
The subframe has had some work done to it, you will notice that the pick up point for the arm has been modified. Also if you look to the rear of the subframe you will notice a little bit of grey primer, both of the holes have had pieces welded in and a cross brace has been put in place for the gearbox mount.
I will post pictures of my surge tank and fuel pumps in the next day or so.
Also note the current 2hp in the engine bay.
hehehe
Dan
