It is currently Fri Jun 20, 2025 11:20 pm
Post new topic Reply to topic  [ 274 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 19  Next
PostPosted: Mon Jun 11, 2012 12:22 pm
Mini Mad wrote:
isn't it 101.6mm (4") not 110PCD?
yes it is 101.6mm.
It's not impossible to change 100mm PCD wheels to 101.6, some wheel shops used to do it by machining the holes bigger & fitting inserts. Not sure if it's legal now..
PostPosted: Mon Jun 11, 2012 12:25 pm
oops, my mind is all muddled from Morris 1100 PCD's driving me crazy.
My explanation still works though ;)
You're so square
Baby I don't care
PostPosted: Mon Jun 11, 2012 8:29 pm
mickmini wrote:
zulu_warrior1976 wrote:
Why is it important? (Excuse my ignorance... I'm not a mechanical engineer)
If you fit 100mm PCD wheels on a 4" PCD hub, you will introduce a bending load to the studs that they are not designed to take. You will also not be able to correctly tighten the nuts, leading to damage to the wheel nut seat in the wheel.
End result in worst case can be broken studs and/or wheels flying off - neither of which you want.
michael
Great info! So will Brad have trouble do you think? I think they look super though and would love to do it on my mini but am concerned about all the down sides the blokes have brought up.
Zulu...
1967 mini Cooper S
PostPosted: Mon Jun 11, 2012 8:49 pm
Brad said he had modified his hubs to 100mm.. so should be OK if done properly.
No details on how he did it.. (personally I would have done the wheels to 4" PCD instead, but I'm a machinist...) :wink:
PostPosted: Tue Jun 12, 2012 5:03 pm
13secmini wrote:
madmorrie wrote:
Looking good. Fingers crossed for ya.
Can you post details of how the conversion to 100mm pcd was done. I think a few would be interested in this.
Madmorrie
Sure, well the secret in doing this is in the wheel stud size. You have to go to a bigger stud, i think i went the next thickness up, they are an old holden/chev stud. With them you can open up the original mini stud hole on the flange. Mine were done by sainty (drag racing team) here in sydney.
They redrilled the 4x100 pcd into the flanges and by using the larger stud it took out the entire original hole.They had to drill the rear drums as well. The front im running camira discs so the rotor is already 4x100. Cost me close to $200 for the work.
1974 Moke - 998cc
PostPosted: Tue Jun 12, 2012 7:32 pm
Very good quality wheels (not ebay crapola) will be available undrilled. You can then have them drilled by a suitable machine shop (i.e. one that understands that 4" is not 101.6mm really) to suit the Mini hubs.
PostPosted: Tue Jun 12, 2012 7:52 pm
Um.. has the metric standard changed much in length lately? last time I looked, 4" was 101.6mm? :?
For all practical purposes anyway, including Mini wheels (IF equispaced on a 101.60mm PCD). :wink:
[edit] from http://www.engineeringtoolbox.com/inche ... d_751.html
4" = 101.6000mm. (I do drop a couple of zeroes on my equipment) :P
PostPosted: Wed Jun 13, 2012 10:05 pm
You know exactly what i mean Kev :roll: measure imperial stuff with imperial tools. But if you have that many zeros you might be able to get away with it, unlike certain aircraft manufacturers early efforts trying to marry up imperial and metric parts.
PostPosted: Fri Jul 20, 2012 9:46 pm
Well my CB80 mini had its maiden voyage today :D
Nothing to exciting, just checking all gears are there and brakes / clutch work properly. Was sent to the dyno on Thursday but had a couple of little issues (small oil leak from oil relocator) Bolt missing on exhuast housing on turbo and 1 injector is not working as it should (looks like its staying open).
Once I fix this I will get it tuned. At the moment it starts and runs up to about 2000rpm before it misfires.
Video here:
http://www.youtube.com/watch?v=TQWL-VvW ... e=youtu.be
http://www.youtube.com/watch?v=apM6jPWLlvM&feature=plcp
http://www.youtube.com/watch?v=3Iv2cu9YWlg&feature=plcp
1974 Moke - 998cc
PostPosted: Fri Jul 20, 2012 10:46 pm
That things sounds awesome!!
Well done man.
Madmorrie
PostPosted: Sat Jul 21, 2012 9:34 am
Sound good and looks good
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sun Jul 22, 2012 7:29 am
Excellent work Brad, looks like it was meant to be there!
PostPosted: Fri Aug 10, 2012 2:51 pm
http://www.youtube.com/watch?v=ATzFewG5 ... e=youtu.be
Lots of fun, cant wait to get rego and on the road.
1974 Moke - 998cc
PostPosted: Fri Aug 10, 2012 3:31 pm
Woohoo! Welldone mate :D
Hurry up and get it registered, so we can go for a drive together 8)
PostPosted: Fri Aug 10, 2012 4:02 pm
Awesome, still sounds like a mini too! Have you wound it up yet?
