It is currently Tue Jun 24, 2025 4:47 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 19, 2009 9:04 am
The nissan brake calipers are similar design to the magna. The magna are an alloy caliper the disc is 9" solid. The thing I found easy for a conversion is the disc rotor has the wheel brgs as part ot the center of disc. The brgs are same as a holden[HT I think] and trailer stub axles are cheap. Machine the stub to fit into mini swing arm and mount the caliper mounting bracket to the original back plate position.
www.minisprintgt.com
PostPosted: Thu Feb 19, 2009 9:53 pm
Just one thing to note about those Skyline rear discs (for anyone who wants to know) - those ones Tricky have are off a Skyline Gts NON-Turbo, not a Gts-t (Turbo). All NA Skylines (R32 onward) are 4 stud and turbos are 5 stud.
The NA rear dics are solid, turbo rear discs are vented (and bigger - about 270-280mm). The calipers on the turbo are also single opposed. I just went out to the garage to double check on my Gts-t.
So if you are thinking about using Skyline discs, just make sure you get the right ones :D
-Alan
PostPosted: Thu Feb 19, 2009 10:14 pm
I'm 99.999% sure they came of an Australian delivered boxy Skyline anyway - 80's model... nothing special
PostPosted: Thu Feb 19, 2009 10:17 pm
R31 Aus-spec Skyline? Yeah - definitely nothing special :lol:
-Alan
PostPosted: Thu Feb 19, 2009 10:23 pm
unless it was one of the ones Jim Richards and Mark Skaife were running... oohhhh baby
I stood beside the pit wall at Wakefield a few years ago, as the ex-Skaife car went past at 240-odd kph - yep - nice cars
PostPosted: Fri Feb 20, 2009 8:13 am
I did say GTS didnt I???
Still, enough rear braking power for a Mini any way you cut it.
That would be this one Simon.....
PostPosted: Fri Feb 20, 2009 9:40 am
<snip>
Yes you did say GTS, but a GTS has been released right through from R31 to R34 Skylines :D The R31 GTS-R is the car that Richards/Skaife drove.
-Alan
PostPosted: Fri Feb 20, 2009 11:14 am
R31 GTS mags are only 15" and have the same PCD as a Suzuki Swift Gti 8)
I have been thinking of using the Gti calipers, but they are cast iron.
PostPosted: Sun Feb 22, 2009 6:47 am
I guess there are a few calipers that you can use, but I am yet to see one as light and compact as Simon's CRX/Civic ones (unless you go custom KAD etc, or motorbike)
Brilliant Simon, truly brilliant (again!) :wink:
Tricky
PostPosted: Mon Mar 02, 2009 4:59 pm
Has anyone done any research on the compact (and lightweight) motorcycle calipers.... there are some real trick 4 and 6 spotters out there, and won't cost too much
Michael
Motivate me to get this done... back in Sydney again...
PostPosted: Mon Mar 02, 2009 5:08 pm
Dave rosenthal is doing some RD into bike calipers etc etc PM him
blokeinamoke wrote:
PostPosted: Tue Mar 03, 2009 1:02 am
Yamaha released 4-pot calipers that ran ventilated discs on their late model FJ1200's I believe. But there is still the problem of what to do about the emergency brake.
PostPosted: Tue Mar 03, 2009 8:24 am
Not sure if it has been discussed yet, but is there really a need for disc brakes on the rear of a mini?
PostPosted: Tue Mar 03, 2009 8:26 am
Yes, to save unsprung mass.
