It is currently Tue Jun 24, 2025 4:10 am
PostPosted: Fri Aug 20, 2010 6:19 pm
Is it any good for a conversion or what?
PostPosted: Fri Aug 20, 2010 6:23 pm
no,,, if it`s not got 5 million HP,,,, big gobs of torque,,,, is far lighter,,, bolts straight in,,, & costs almost nothing
then don`t do it
PostPosted: Fri Aug 20, 2010 10:37 pm
It depends, if your converting it into a 1990 corolla with a stuffed engine itd be fantastic.
In a mini the auto on toyotas is quite large, so bulkhead mods would need to be done.
Simplify and add lightness
PostPosted: Fri Aug 20, 2010 11:57 pm
jeez - I moved that other thread into other makes because I thought you'd put it in here by mistake and you were just asking if it was OK for a runabout.... I didn't expect anyone would want to put one of those in a mini, yukko
PostPosted: Sat Aug 21, 2010 12:22 am
Ha I thought I had posted it but wasn't sure when I couldn't find it :? I just thought because it's from the Toyota 4A... family it may have been worth a look. I wasn't to sure about the auto either, had a feeling it would be too big.
PostPosted: Sun Aug 22, 2010 1:00 am
A 4AFE is just a more fuel efficient version of the 4AGE. Similar size, interchangeable block and gearbox.
If you were going to go to the effort of using a 4a engine, then you would be much better off using the 4AGE.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
