Engine Size 1.498 L / 1.323 L
No. Cylinders Four cylinder
Fuel ULP
Transmission Four speed automatic or five speed manual
Wheels Driven Front Wheel
Acceleration 14.5 secs / 12.2 secs
Warranty Three years, 80,000 km
Engine
Engine Type Four cylinder, in-line, SOHC, 16 valves
Capacity in Litres 1.498 L / 1.323 L
Induction Electronic fuel injection
Fuel Recommendation ULP
Claimed max. power 64 kW at 5500 rpm / 53 kW at 5500 rpm
Claimed max. torque 128 Nm at 3500 rpm / 107 Nm at 3000 rpm
Power (kW per 1000kg) 42.7 kW/litre / 40.1 kW/litre
Transmission
Type Manual / Four speed automatic or five speed manual
Wheels
Alloy Steel
Dimensions 5.5 x 14 inch / 4.5 x 13 inch
Tyres
Steering
Type Power assisted rack and pinion
Turning Circle 3.1
Turning Circle (measured) 9.8 metresm
Dimensions
Mass 970 kg / 910 kg
Length 3800 mm
Width (including mirrors) 1650 mm
Height 1500 mm
Ground clearance 140 mm
Seating capacity 5
Fuel capacity 40 litres
Towing
Max. towed mass (trailer plus load) 700 kg
NRMA Theft Rating
Points on scale 0 - 120 (high score is best) 22
Acceleration - Test results
50 - 80km/h 6.8 secs / 6.5 secs
60 - 100km/h 9.9 secs / 8.2 secs
0 - 80km/h 9.3 secs / 7.6 secs
0 - 100km/h 14.5 secs / 12.2 secs
Fuel Consumption
Best recorded during testing 8.1 L / 7.4 L
Worst recorded during testing 9.0 L / 7.9 L
Average on test 8.4 L / 7.6 L
Braking
Distance to stop (from 80km/h) 31.7 metres / 35.5 metres
Noise
Interior noise at constant 80km/h 71 dB(A)
& yea these things are FUGLY
