I wouldn't bother too much with A/C.
I had big plans with AC for my starlet Mini (currently still in the making). Was going to use the starlet compressor and use the Rover Mini matrix and under dash unit with custom piping.
Until I got the motor in the car....
There's bugger all room and my alternator is mounted backwards through a hole in the inner guard (like many others have done) and I really don't want to cut the hole bugger and put the compressor in the wheel arch too, I think that's going to far.
I did end up buying a Rover AC setup then went forget this! They're going in the other Clubby
. (If you are going to get Rover AC gear for a clubby you should know that the Rover under dash unit does NOT fit next to a standard clubman heater, you will need a Rover heater or similar)
1977 Leyland Mini LS - Project LS-T
