It is currently Wed Jun 25, 2025 9:27 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Oct 28, 2009 4:23 pm
Thats pretty much sold it for me then.
And only a little bit of panel work to fit it. Plus a spare ct9 to use on my daily :twisted: :twisted: :twisted:
Simplify and add lightness
PostPosted: Wed Oct 28, 2009 7:39 pm
Is the KKR a ball bearing design?
PostPosted: Thu Oct 29, 2009 8:50 am
Nope - brass bushing, with force fed oiling.
PostPosted: Thu Oct 29, 2009 8:52 am
Nothing wrong with that tho,,, the bush type turbos have been running wonderfully for years & years & years with no dramas, the trick (or one of them) with the ball bearing turbos is that they spool up easier/quicker, but yes thery`re more expensive
PostPosted: Thu Oct 29, 2009 11:42 am
Yes Matt, not as frictionless as ball bearing, but bullet proof really and does what it says on the box. Equally unless your doing the Nordschliefe the lag difference is minimal...
PostPosted: Fri Oct 30, 2009 1:19 pm
is the KKR280 a similar or same flange size as the T25 which might be a T2 flange size?
1972 Leyland Clubman, 4EFTE 1330cc Turbo, 220Hp on 17psi
(1/4 mile: 13.8s @108mph @168Hp)
PostPosted: Fri Oct 30, 2009 3:47 pm
T25/28 are different to T2
T25/28 is rectangular ... & the T2 is basically square
but easy fixed by swapping the flange, or adapting the flange on the manifold
PostPosted: Wed Nov 04, 2009 12:21 pm
I think from memory it takes a T25 flange.
