It is currently Wed Jun 25, 2025 9:26 am
PostPosted: Sun May 03, 2009 9:33 pm
My clutch slave has just started to have a small leak and upon further research seems to be a common thing for them to go.
Especially if they sit around for ages in a front cut before being put into a mini and then actually used.
It's fairly easy to access and replace, but for those who what to be extra cautious it might be a good idea to replace it and save the headache later :)
PostPosted: Mon May 04, 2009 4:44 pm
Just another thing to add to the list :roll:
Its just getting longer and longer :shock:
Life's a garden.... Dig It!
PostPosted: Mon May 04, 2009 10:44 pm
How much will/did the slave set you back?
-Alan
PostPosted: Tue May 05, 2009 9:57 am
I havn't got a quote yet but anything from $40-70 is what i've seen floating around the net.
PostPosted: Tue May 05, 2009 10:52 am
Ah relative peanuts then & easy enough to remove/install.
-Alan
PostPosted: Tue May 05, 2009 7:06 pm
You should be able to rebuild them.
I have a couple of spare slave cylinders I'm pretty sure if anyone's interested. :wink:
-James.
Toyota 4EFTE Powered Minivan.
