Ray the turbo is of a s14 nissan silvia. The turbo is known as a T25g, not bad for a $200 turbo and $200 manifold hey
They do not make much power over 17psi as they run out of puff, when i had it on the dyno it would make the same power at 14psi as it did at 17psi, but i think that was to do with the top mount intercooler.
Lag was not that bad with the top mount, plus the car dosnt weigh 2 tonne so it only lagged once, that was in first gear when you need it to, but once you hit second gear you were already past the lag so it just powered through the rest of the gears.
When i got the 1/2 cut it was stock as a rock no mods what so ever and around 70k on the clock i think. I dont think the injectors would have been touched as not even the air box was touched and the stock turbo and manifold had never been removed by the looks of it.
They could have modified the motor in japan and then put it back to stock when crashed and forgot about the injectors maybe, but the stock ecu usually dosnt like run so smoothly with bigger injectors, and this motor ran like it was brand new.
I put a fuel cut controller on it to run higher boost then the ecu cut off, think its about 12psi. fuel pump was vl turbo and a sard fuel regulator. That was all the mods i did, now ray has a front mount and fixed the wastegate actuator and a tune for over 200hp.
To me that is a pretty impressive result from so little mods from 1330cc.
1974 Moke - 998cc
